Results 1 to 26 of 26
Thread: Answers 2 some simple turbo questions?
    The Dark Lude dakilla4ever's Avatar
    In the Darkness
    Default Answers 2 some simple turbo questions?
    Can anyone answer my questions. How much is you gas mileage effected when you turbo your car? Do you lose or gain mpg? After turbo will i be able to pass emisions? What will i have to do to make it handle daily driving? Or is it daily drivable? Any answers would be very helpful. -H23 LUDE
    Barefoot Racing stealthrt's Avatar
    Dunwoody
    When I turbo'd my car, I actually imporved my gas mileage. But that is mostly due to the fact that I tuned my car once becoming turbo. I daily drive my car every chance I get, but it is undoubtly down more often than it would have been had I left it NA.
    Passing emmisions also became more dificult. The first year, I sat in the car while it was on the dyno (or whatever they call it) and tuned it to 15.0 (with an SAFC) to make it pass. After that, I upgraded turbos again and didn't even want to deal with it, so I registered my car out of the emissions area.
    Now my car gets even better gas mileage (assuming I'm not too heavy on the throttle) because I have an even better fuel managment system. Right now My Maftpro will self adjust while cruising (as well as at WOT) to whatever AFR I tell it, so I usually cruise around with a 16.0 AFR. When I get on it, that mileage goes to shit.. but thats pretty obvious!
    In the Darkness
    But it is possible to pass emmisions? Just takes alot of time. How often was the car actually running as oppose to it being worked on.... like how many days out of the week was it being worked on compared to you being able to drive it? What kinda problems do you run into?
    Jay G. 1439/2000's Avatar
    Location, Location...
    Hmm well stock turbo cars pass emissions......
    I know plenty of other na converted turbo cars that pass too.
    Drifter/Kneedragger
    Buford, GA, USA
    Quote Originally Posted by dakilla4ever
    passing emissions depends entirely on the EXACT setup of the car and the overall internal condition of the motor. nobody here can answer your question truthfully.
    Patience Pays...
    I dont know other setups but I know on my G35 my highway mileage went from 22mpg to 34mpg-36mpg after adding turbos.. Drove from my house in Douglasville to Charlotte on a 3rd of a tank of gas. It was my daily driver till I sold it.
    As far as emissions goes, I'm not sure. My car never threw a code so I had no problems.
    Dunwoody
    Yes, It is possible. When I had my old turbos (MUCH smaller) My car ran probably 10 months out of the year. Now it is likely to see 6 months, although 3 of that was doing the custom setup / waiting on built engine.
    Quote Originally Posted by 1439/2000
    Very true, and in my case I would have easily passed, But I was running larger injectors, SAFC, no EGR, no precats. So it was a little harder than usual. Not to mention the VR4 has problems passing on its own. Why do you think it is the car on the front of the "Guaranteed to pass emissions" stuff?
    In the Darkness
    Ok so what would anyone recommend for a 95 Prelude Si? Ebay or Turbonetics? What would i need to do to my motor to prepare it for turbo? If by any chance there is a list os stuff i will need to complete this.....that would be very helpful. Preciate it.
    In the Darkness
    I was thinking
    T3/T4 Turbonetics Kit
    AEM Plug & Play ecu
    Crower Stage 2 Turbo Camshafts
    JE 9:1 Piston Kit
    Crower Billet Connecting Rods
    Crower Performance Spring & Retainer Kit
    Skunk2 66mm Throttle Body
    Venom Intake Manifold
    Limited Slip Differential
    Stage 2 Clutch
    Fuel Pressure Regulator
    Fuel Rail
    Piston Ring Set
    Head Gasket
    Fuel Injectors
    Performance Radiator
    Radiator Fans
    But this is just a wish list. College budgets don't agree with me and upgrades.
    Alpharetta/Duluth
    Get the Turbonetics kit, uberdata ecu, tune it, and call it a day. Don't try to do everything at once if you are in college. 8-10lbs boost on a tuned H23 will be plenty fast for a good while and you can see how much you like it before dumping a ton of money into, and then deciding that you are unhappy or tired with the project.
    In the Darkness
    I won't need to have the head gasket changed?
    Northwest Georgia
    nah, I and many other people use OEM headgaskets on 700+ hp applications.
    my gas mileage went up or stayed the same on my last builds. 500-600whp. a bigger turbo will not spool as easy as a smaller turbo of course so the less you are in boost daily driving, the more stock amount of fuel is pumped into your engine. When you hit boost, that gas disappears like a fat kid gobbling creme pie.
    mmm creme pie!!
    i just filled up on the way home tonight and got 37mpg. that was also trying to screw with my a/c system that went out and i had my car idling for probably 45 minutes or more on this tank so w/o doing that i could've squeezed out 38-40mpg maybe. 85whp stock motor making over 200whp daily driven.
    In the Darkness
    On what type of car? And what type of turbo kit? I heard i can get one cheap on ebay?
    The theory, "You get what you pay for", applies to purchasing a turbo setup. I believe the company, SSAutochrome builds some of the worst manifolds. Poor welds and craftsmanship. The sell their kits off of E-bay, the turbos arent that bad of ebay though, just stay away from those manifolds. This is all hear say. I would much rather save a little extra and get a better product. Good luck though. I just finished gathering all of my boost parts this afternoon. BOOST...Here I come!
    Boosted 4door
    Quote Originally Posted by integra2die4
    I'm gonna have to go w/ the other way around....ebay (ssautochrome) turbos are junk and their new manifolds they sell are alright. as long as they are braced properly they wont crack. i'm not saying they are the best thing out there but for a budget turbo kit they are pretty good.
    my car went from around 350 miles out of a tank of gas(non highway) to around 250 miles...but thats because im running a t25 on a 2.2 liter so i'm in boost or almost in boost almost all the time. plus i haven't really ever gotten around to fine tuning my vacum half of my fuel maps to get good gas mileage. i just had my boost portion of my map and got lazy.
    Gainesville
    hey Tony do you work at a car lot off P.Hill road??
    Georgia Muscle twinj's Avatar
    Da "A" Niccuh
    You can pass emission if you keep your set up simple. Don't try to shoot for some all out race type of deal. My gas is about the same and far as passing emission yes i can pass. I drive my car every single day. So yeah You can daily drive i only get on it hard when i am at hangouts and playing around. GET A PROFESSIONAL OR SHOP SO YOU WON'T HAVE ANY PROBLEMS. That is where alot of people mess up do it right the first time don't get cheap parts
    In the Darkness
    cool. so what do you recommend? Any particular brand or maybe i should get a muffler shop to make me a manifold for it. Does anyone know how much that cost, or have any ideas on the setup i should go with?
    Da "A" Niccuh
    Mainstream as the shop. As far as setup it depends on what you want
    Da "A" Niccuh
    Mainstream( they will do the mainifold and all fabrication) as the shop. As far as setup it depends on what you want to keep it dependable no more than 7Ibs. Everything else just depends on you and what you want out of it.
    In the Darkness
    Does anyone know how much a REV-HARD turbo manifold cost?
    i thought u were going all motor. lol boost is the way to go with a honda.
    In the Darkness
    Yeah well im still undecided. I want to go all motor but i dont know if i can still run 93 octane on a 13:1 compression motor. If i can i'm going with that. But if i cant then im gonna turbo it. Some dude told me tonight to turbo it now then when i blew the motor just rebuild it better. Rather than building it right the first time and not having to even think about it failing.
    there is no way in hell u can run pump gas with 13:1 compression. and i would just boost it safely, and then when u get the money build it better. i wouldnt blow it then build it. cause u will prolly mees alot of shit up. just boost like 7 lns and be safe. that is my .02
    In the Darkness
    So just put a turbo kit on my stock motor. Until i can build the motor?
