Okay need help lol. A lot of backstory so please bear with me. redtop SR20DET in 89 240sx. Just got out of local performance shop. Engine rebuilt, all oem nissan bearings/rings/seals/etc. Brand new head. New timing chain, tensioner, water pump, timing chain cover.
Peak Performance Gold Valve Springs
APEX .8mm headgasket
HKS Step 1 264 intake/exhaust camshafts
Greddy Rocker Arm Stoppers
Nismo thermostat
Pro-Fab Intake Manifold Gasket
SARD 550cc Injectors
ARP Rod bolts
ARP headstud kit
Walboro 255lph
NISMO FPR
Garrett GT25R .64
Z32 MAFS
FMIC
3" intake/exhaust
Greddy Profec Type - S
Greddy Turbo Timer
Enthalpy Tuned ECU (Z32, 550cc)
Just got the chips two days ago (old ones were corrupted) Car starts, runs extremely rich (wideband showed idle 10:1 a/f) will idle rough when cold, once warmed up will not idle. The minute you take your foot off the gas, shuts off. Car runs real boggy/bucky lower rpms, once it clears the gas out higher rpms runs good.
Planning on going to florida sometime soon and meeting scott there and having them dyno/examine/fix car if it is the tune. Just doing this to see if there is a possiblitly of it being ANYTHING else.
Also, while car was in shop, removed ecu and hooked up aem ems and car ran perfect. Good idle.
Things I have checked
O-rings, not leaky.
Boost leaks - none.
CTS - Brand new
MAFS - Good
TPS - Good
Spark Plugs/coil packs - Good
All wiring on car was checked over, some redone (some wires were butt connected 2 or three times from the half-assed motor swap done before I got the car. All of it is single wires, shielded)
Everything else on the car is perfect.
At its rough idle stays around 1k, shows a vac of ~10-12.
Fuel pressure is dead on, have a defi gauge inside. Increases 1:1 for boost. Idle ~40psi
Please please help. I can barely drive the car, shuts off whenever I cant hit the gas. Its going to be expensive for me to get it down to florida (dont want to drive it, got to get a friend to help get a trailer to take it down there. Plus about 7-8hrs away.) Is there anything else it could be besides the tune? PS Ecu is good, was checked out at enthalpy while car was in shop.
