Results 1 to 23 of 23
Thread: New VQ35
    C7 On_Her_Face's Avatar
    Duluth
    Default New VQ35
    has anybody heard anything about it, ive heard there will be a vq35hr (high rev that revs up to 7.5k? anybody else hear this?.. will it come out in 07? or will there be any changes from the 06 to the 07 motor?
    Blooregard Q. Kazoo turbosx©'s Avatar
    femalesaplenty
    dual throttle bodies to
    I got dinner to goto.
    Duluth
    ya i heard that but is that gonna happen in 07 or 08?
    Patience Pays...
    The 07 G Sedan has it, I've heard that the rev limit is 7.5k and pushing about 310hp. Torque is supposedly still in the 260 range though.
    Somewhere down the line I think a 3.7L V6 is expected. I just found out I get VPP pricing with Nissan/Infiniti so I'm really waiting to see what they come with in the next couple of years. (Especially the GT-R)
    Click me
    Read near the bottom of the article on the first page, no major details, improved cylinder head cooling, variable intake, ect.
    Also the QR25DE underwent some changes, again no major details but, the rumors are a taller block, longer rods (better rod to stroke ratio), more agressive camshafts, larger diameter rod journals, and more stable at higher RPMs, 7000ish. Time will tell.
    by my nieghbor.........
    mine revs to 75ook.
    All Motor EK N/A EK's Avatar
    On IA.com
    mine revs up to 6.8 almost 7
    Quote Originally Posted by T0PS3-R
    hey man just wanted to say that you have a clean ass spec homie :boobies:
    Public Enemy #1
    dude 6.8 is the highest you have gotten i have gotten mine right RIGHT above 7....like 7.1 or something!!!!!! but mine is also a different engine!
    On IA.com
    Quote Originally Posted by nIsMoSleePer
    Thanks, Ur Alti is clean too
    On IA.com
    My friend just got a 06 spec(3-5 month ago)and he can't get even close to the redline. The most he gets to is 6.2 or something, but its still a brand new car!
    Quote Originally Posted by T0PSE-R
    Hmmm, the stock rev limit is 6250. 6800, are you running a standalone, or a reflashed ECU, otherwise I call BS, Nissan must have given you a faulty tach.
    Miss my Civic.
    Ill back him up on the 6800...only if he was on the highway...flooring it in third, then down shifted to second and dumped the clutch...for that few millionths of a second...he could hit 6800...
    On IA.com
    Quote Originally Posted by Big J
    Yes, the stock rev limiter starts at 6.2 or 6.3 but it doesnt mean that its gonna stop there and not let u go down more. You can also rev it EASY at 6.5-6.6. Just got to kno how to drive u car man
    Free rev or pull. The ECU stop the fuel injectors at 6250, momentum carries the tach neddle past 6250 on the guage.
    The double spike in the green line is me hitting the rev limiter @ 6190ish. I'll log on the way to work and bang the limiter good, fuel cut will happen at 6250. Inertia will pull the motor a few more revs and the ignition will keep sparking, the logger will keep regestering RPM even after the cut. You'll just have to watch the green line in comparason to the blue line.
    On IA.com
    cool chart
    Ok I banged the rev limiter twice for arguments sake, a picture is worth a thousand words
    Purple line is throttle %
    Blue is RPM
    Green is air fuel ratio
    light blue (user imput) is MAF voltage
    (EGT and Manifold pressure (boost) logging not being used YET)
    The color coded values at the right are derived where the vertical white line intersects the logged values
    Notice the small dip in the A/F just to the right of the white line, that's where the ECU takes over and starts to cut fuel, that dip starts on both graphs a 6227. During the rev cut the RPMs do go higher than 6250, but it's not really going to contribute to acceleration. If you come off throttle while in gear the A/F will go to 21 (that's what % is in the atmosphere), so if your lifting to shift anyway and the fuel's going to be cut either because of the lift or the rev limit, these are going to overlap, and the ECU will be satisified, and inertia will carry the revs past the limit w/o really hitting the fuel cut, unless you stay in the throttle. A rev limiter won't do a thing if you miss shift into a lower gear.
    On IA.com
    ^u got a comp. in your car or something?
    Only when I data log or tune, other than that just the ZT-2 unit and S-AFC II.
    BLAH BLAH BLAH!!!!!! Georgia_boy's Avatar
    Southside
    damn J, you high tech nerd
    j/k man
    Quote Originally Posted by georgiaboy85
    j/k man
    I'll remember that when you need some high tech nerd work done
    When are you going to get the talon running?
    Southside
    ASAP
    if my money situation pans out.
