Thread: need help on instaling a ssq bov
    lol mexicans
    in a house
    Default need help on instaling a ssq bov
    if anybody knows how to install a bov, please let me know im trying to save some money and im not really an expert on turbocharged cars ,...
    georgia
    what kind of intake pipe do you have steel or aluminum? all you need to do is pick a place on your intake to mount the b.o.v mark a spot and and cut a hole,lay the flange for the b.o.v (i hope you have one) and weld the flange in place.then you will put the rubber o ring into the flange and install b.o.v and then the C clip,it helps to have the tool to put it in.then run you vacume line to the engine,pretty much any where you can T into the line.a plastic T will work fine.dont foget the little ssq filter that goes in line to the vacume on the engine. if you cant weld ive seen people use jb weld,i welded mine. all this will work for you,unless you car came with a turbo and b.o.v.then you will need to buy a flange for your car.
    yes i am....
    Drifter/Kneedragger
    Buford, GA, USA
    from the vaugeness of your question and self proclaimed lack of knowledge this will not be a DIY type project for you. it will require fabrication (cutting and welding) unless you can find a kit that will bolt onto your car. i'd suggest taking it to a shop to have it done, if you bring them the flange and the pipe then they can do the fabrication part and you can simply bolt the pipe back in and run a vacuum line.
    Team Korupshun DamnDisLaOsBoY's Avatar
    Lawrenceville, Ga
    easy! just trade for my greddy type s! lol
    Banned KL_03Mx-3's Avatar
    Calhoun
    what kind of question is that??? u do not neccisarily need a bov you could put a recurcualtion vaule on it but as it seems you aren't a DIY kind of person so dont worry about it
    20 side of thangs
    on some cars a flange is not needed for installing an aftermarket blow off valve. my friend didnt need one for his eclipse.
