Results 1 to 40 of 42
Thread: HEAD WORK PRO IN GA!!!
    everywhere & nowhere
    Default HEAD WORK PRO IN GA!!!
    Aiight, so who is THE fuckin man for a GANGSTA ass head job. (that did NOT come out right... LOL). I am not talking about your girlfriend (although she IS good... LOL), I am talkin about for a B series head spec'd for N/A duties. NOT "fully-bolted" duties... REAL N/A duty... there is a difference (no offense).
    DFE?
    Sunbelt?
    I am not talkin about no BS either... I can simply ship to inlinepro in VA and KNOW I am getting good shit. DPR (Dan Paramore racing) charges around $1100 too w/ quick turnaround. If you do not know http://www.dprracing.com/ then you are a NOOB, and your input prolly will mean nothing to this thread.
    Who's the man/shop "in-house" (locally) though.
    Senior Member 99SI's Avatar
    Jackson
    DFE Jacksonville. From what I've seen and heard myself that's the place I would be sending to, and the place I will send mine to eventually. Can't argue with numbers and he's the one that did Mike's head as well as the LS head that they are doing right now. I've seen the ports on both and they are very lovely, plus he flowbenches the head and you have hard data to see where not only cfm is higher but velocity as well. Most people only think that CFM is what makes a good head and that is the furthest thing from the truth. Velocity has as much to do with power output as the actual AMOUNT of air flowing(CFM). But you need to keep in mind that you need a header to go with that new headwork!
    To 942JZGTE 93H22ACX's Avatar
    Head flow research
    94 Supra= 500rwhp
    Thanks every1.
    DFE ENterprises for a fully worked head. every head from Don has been PERFECT an acheived the goals i needed.
    Also, we have ordered 3 of the Skunk2 Digital CNC heads, an those are great as well, although a little more expensive. $1300 with a CORE an they come bare. $1850 fully assembled with a core
    Head Flow Research did Peter Hues head, an it def made some sick numbers/
    but locally, for an ALL MOTOR car i wouldnt trust anyone locally, my .02
    ... and you know your .02 is worth WAY more to me. Thanx Mike. You know why I am asking... every1 else will find out soon enuff.
    DPR sucks LOL
    TBONE had a DPR Stage 6 head on his motor. 13.6:1 compression an made 248whp. The head blew up or something went wrong, he had RLZ do it, DROPPED a point in compression an made 255whp. 7whp gain with LESS compression.
    cant argue with that either
    Hmmm.... too may variables to know. But I'd say that he had WAY too much head (Stage VI) for only 255 wheel.
    **chuckle** "too much head". LOL. I said too much head. Tee hee.
    There are 12:5:1 B series' putting close to 280 down.
    as far as i know, TBONE had the highest street car B series around with 255whp on pump gas.
    There are people making 270-280whp with 95mm cranks, he only had a 2.0l with a 87mm GSR crank, so that makes it even more impressive.
    Did he have a massaged B16 intake manifold or did he go big??
    http://honda-tech.com/zerothread?id=1185009
    Quote Originally Posted by TBONE
    Heres a link to the old post, I started a new one as the old one was getting to long and the mods dont like that.
    http://www.honda-tech.com/zerothread?id=1139085
    A quick recap..
    My cyl head needed repair after bending some valves while doing cam testing.
    Head was originally a DPR stage 6 head that was reworked and modified by Racingflow after me bending valves after Dpr had oringinally done the work.
    This was a 100% completey ported head that had made 247 at one point in time in its running on my car..
    I sent the head to Brad at RLZ engineering for repair and he told me that he felt that he could modfy the alreay ported head to pick up mopre power and thats how this whole thing started..
    My last dyno pulls made on a dynojet refleted the wear and tear on the motor as it has over 10,000 miles on it and over 300 dyno pulls and my power had dropped to 236.9 whpand 155 tq.
    Heres the current setup as dynoed..
    85 mm bore Dart block
    stock gsr 87.2m stroke
    endyn oil pump
    12.5 cr.. All my previous dynos were at 13.5 so that makes these gains all the moe impressive
    RLZ modified ITR cyl head with 1mm oversize Ferrea intake valves and stock size exhaust valves
    Jenvey 48mm ITB's with 580 cc injectors
    Hondata s200
    Smsp header with 2 3/4 exhaust stepped up to 3 inch from the cat back
    Distributor King dist with msd 6al ignition,blaster ss coil and stock plug wires .
    105 oct unleaded pump gas..
    This is an overlay from my last runs made on a dynojet to my high run made this week after the cyl head modifcation.
    h0tn3$$
    that was on 105octane, i stand corrected. it wasnt pump. but a 2.0l NON LS crank making that at 12.5:1 is INSANE.
    my motor was 12.2ish:1 an never went over 237whp. hes a solid 20whp more. granted he has ITBs, but still, thats ALOT of power
    Fuck yeah. I think www.racelinedevelopment.com are the reigning N/A pump gas (12:5:1) kings... lemme see if I can find their last build.
    Banned LS2ner's Avatar
    The Face
    pffft everyone knows i do the best headwork....oh wait, nm....
    LOL..... innnnnnnnnteresting. LOL
    KMS engine development, in Conyers. click here I don't know much about them, but they specalize in hondas and are local, just another option.
    KMS IS A RIPOFF, HE DOES SHITTY WORK, and has NO IDEA WHAT HE IS DOING . he blows more shit up than anyone in GA.
    BEWARE, DO NOT GO USE KMS
    So uhhh... I'm not the brightest guy in the world... but something is giving me the feeling that you do not want me to use KMS? LOL
    search his name on Honda-Tech, hes about as bad as Dave Hickman, but i think hes worse. Hickman actualyl has a fast car himself, KMS slaps shit together an it never works, i have torn down 2 of motors he built for someone else. they were the WORST display of machine work an assembly i have ever seen.
    Both motors lasted 1500miles befroe they blew up. I have NEVER seen a motor spin EVERY rod bearing an EVERY main bearing, have thrust washers installed backwards, an the piston to wall clearance be 1.2 a thousandth for a forged piston.
    IDIOT plain an simple
    So --> went to his site for shits and giggles... who manufactures his house-brand (KMS) pistons and valve-train components? Surely he is not forging them in-house? If so he has at LEAST 1/2 a million dollars worth of tooling (machining for peeps that do not know what tooling means) hardware. That's impressive even if he doesn't know how to spec them properly.
    SUPERTECH, all his stuff is SUPERTECH. Supertech is a great company, he just buys their stuff in bulk an repackages it as his own.
    also, his Eagle rods are $50 more than what you can walk into NOPI an buy them for.
    BK all day APEX i GSR's Avatar
    KMS did a cylinder head repair for my cousins car and it actually came out good. I heard you have to catch him on a good day. I guess we got lucky.
    Hey vteckidd it was the 98 GSR with Greddy kit that your shop tuned in January. I think i'm gonna stick with Portflow
    Wow.... things you learn just by posing a simple question. Wow.
    Quote Originally Posted by APEX i GSR
    yeah, i have HEARd that too, that some people with SIMPLE jobs he does ok with, depends what mood hes in.
    I had a friend that waited 6 months to get his motor back, it was a simple rods an pistons b20vtec. Thats the one that spu every rod bearing an main bearing.
    here are people i would reccomend:
    DFE Enterprises
    Headflow Research
    RLZ Engineering
    PORTFLOW
    Skunk2
    Headgames
    I can do head work
    Just kidding
    Try Doug at topspeed.
    I said I didn't know much about them, now I do (taken with a grain of intraweb salt).
    hey Mike... are you up tp speed on the projects coming out of www.sfp.net
    That's a hot shop. Too far away for my liking though. I kinda heard they had some funding issues though. I have seen a LOT of great shops go under.
    Hampton, Ga
    Quote Originally Posted by LS2ner
    port and polish to I bet
    I know South FLorida Performance, again, they make decent turbo manifolds, but they are a Domestic Shop Primarily. I wouldnt let them do an all motor car.
    Rumor has it they are moving up here to Atlanta, that will be interesting.
    I heard they are/were moving North, and I also heard ATL, but I also heard Columbia, SC... but I didn't want to start the rumor mill. I wouldn't say they are a domestic shop --> they got some bad ass Civics (imports). But they are no real N/A threat. I would say that they are boost-heads though. They got some sick boosted shit.
    In the Fucking A
    Quote Originally Posted by aaronfelipe
    Are you fucking serious, I dont even know what to say to this other than
    THEY ARENT A MACHINE SHOP
    Stay out of the big boy threads
    I fucked ©hris's mom
    LOL. Hey Wurm, I do not think you are exactly sure of what I was looking for. Saul Goode... but uhhh, no.
    Soul Crusher RUFFIAN's Avatar
    in your nightmares
    I've gotten some very good feedback about allied motor sports in east point. ph#404766-9955 they also put me onto mike lasiter at 404-790-5956 he builts a lot of race cars. good luck
    Attached Thumbnails Attached Thumbnails -tn%5fblack%20sierrat%2ejpg-jpg
    N/A>>><<<BOOST
    ®anj-♠ ranj's Avatar
    ha ha ha
    All bark, no bite.
    I'm a little biased, but I like DFE.
    WEST_SIDE
    IMO portflow does ALOT of good work i seen in the streets on cali. doesnt ENDYN do head work also .
