Results 1 to 16 of 16
Thread: Mazda Motor List
    Gainesville
    Question Mazda Motor List
    Could someone PM me or post a list or a link to a list of all Mazda motor?Thanks!!
    Oviedo, FL
    Quote Originally Posted by §treet_§peed
    Bah I was looking for the link but unable to find it. turborx7.com has a page with a lot of Mazda motor info. There is a specific page that lists all motors from the first one made I think.
    Gainesville
    thanks
    88 Mazda 323 GTX
    Dahlonega
    How about all the B series
    b3 = 1.3 sohc carb
    B5 = 1.5 sohc carb
    b6 E = 1.6 sohc
    b6 me = 1.6 sohc "16 valve"
    b6 de = 1.6 dohc
    b6 T = 1.6 dohc turbo
    b8 me = 1.8 sohc
    b8 ze "AKA BP" = 1.8 dohc
    BP T = 1.8 dohc Turbo
    GTR BPT "210 hp" = 1.8 dohc turbo
    pn = desel 1.7
    rf = desel 2.0
    KFZE = 2.0 V6
    KLZE = 2.5 v6
    FSVZ = 2.0 dohc I4
    ZL DZ = 1.5 dohc
    ZL VE = 1.5 dohc
    List
    Gainesville
    that helps! thanks!!
    wherever
    Quote Originally Posted by Wingman0
    List
    I'm suprised there's not a denomination for the low and high compression versions....
    I have the high comp. version (99-05 Miata), i was thinking about using the lower comp. block with my head, but i've always been a fan of high comp. low boost engine.. but i guess 12psi isnt very "low boost" for 10:1 compression lol.... probably should switch to the 9.5:1 block from the 94-97 Miata's.
    02' Miata
    88 Mazda 323 GTX
    Dahlonega
    what do you know your right. lol Yea there's a automatic motor and the manual motor. One is higher compression than the other. that's funny
    10:1 @ 12psi thats nuts. Your going to fry your motor if you don't watch it. lol
    I would definitly suggest that you go with the lower compression pistons. you dont need the bottom end or the block, just the pistons I dont think there are really any differance is the block or rods.
    wherever
    Now that YOU mention it, there are 3 versions. The ones i mentioned above are for manual cars, i dunno the specs on the a/t ones though.
    As for CP on my car, you know the real thing about it is intake temps. The colder you can make them, the more boost you can run. I should say, im not at 12psi on my 99 yet, still at 7-8.5psi.... once i do the 60mm s/c pulley , it'll go to 11-12 psi (will add intercooler, injectors and SAFC too). I was running 10-11psi on my 96 though with no detonation at all. I was even runnign 14* advance timing. The key was big injectors annnnnnd intake temps. Between all the heatshielding to keep exhaust heat away, the air inlets (turn signal intakes on Miatas) and the intercooler, the coolant lines removed from the t/b, 160* t-stat and a huge KOYO radiator (55mm)... i had no problems with heat.... hell my intake manifold never got much warmer then ambient temps when it wa warm outside and when it got cold (for the short time i had the car while it was cool out) i would say intake temps at the manifold were no more then 10* max more then ambient.
    Somone once told me that a Jackson Racing s/c will never blow more then 10psi..... hell the s/c on a Cooper S is the same M45 blower and its pushing 11psi stock on the S.
    But yeah, there are 3 versions of the "BP" 1.8L in the Miatas. Whats the motor code for the 2.0L Protoge fro mthe early/mid 90's?? It was a DOHC engine.....looks like this... (yes, thats my old Miata).I figured out the valvecovers were interchangable with minor mods... looks much better then stock Miata.
    stock Miata cover
    02' Miata
    88 Mazda 323 GTX
    Dahlonega
    did they make one??? All I can find is the 2.0 desal and it's RF or are you talking about the 2.0 V6 klze??
    wherever
    I'm pretty sure its a 2.0L...maybe a 1.8L?, dont know much about protoge's. But does that black valvecover look familiar?? Shit, ask JITB on here, he had a Protoge with the 4-banger im talking about (later swapped a KZLE thoguh)
    02' Miata
    88 Mazda 323 GTX
    Dahlonega
    I'm pretty sure that it's was a 1.8. Like the black valve cover It looks a lot better than the stock one. surprised that they didn't inset the valve cover lettering like the 1.6 valve cover
    Isolated Twinturbo6's Avatar
    Savannah
    the KLZE is actually a jspec kl03 it's a 2.5 liter engine. Used in the 626, mx6 etc....
    88 Mazda 323 GTX
    Dahlonega
    what do you know your right i'll edit my post thanks
    ALL CAPS JITB's Avatar
    THe FE3 2.0 Dohc is made off the F2 2.2 motors found in teh 1g Probe/mx6 that came witht he turbo option (F2T) in the 89-92 MX6 GT and Probe GT, but it is built like the 1.8 BP dohc. it was used in the model jspec/edm 626's /mx6's(capella) and it used to be used in the Kia Sportage trucks. Very very stout and strong motor. Alot of people swap them into 1st g probes/mx6/626. They are rated @ 170hp/160tq (or somewhere near that) in the jdm/edm version. But the usdm detuned version foudn in the sportage is 130hp/tq.
    info:
    http://members.aol.com/solomiata/FE3info.html
    http://www.cardomain.com/ride/498351
    Picture of it it looks exactly like the BP just obviously bigger.. hard motor to come by.
    But this isnt the same motor as THe 2.0 FS that was in the newer proteges, adn the Mazdaspeed protege.
    add some more to the list:
    2.2 F2
    2.2 Turbo F2t
    2.0 FE3
    KLDE us 2.5 v6
    KJ(de?) Supercharged 2.3l V6
    JFT 3.0 Turbo
    Mazda Green Turd KLZE's Avatar
    Lawrenceville, Ga
    The KJ is KJ-ZEM I believe the M stands for Miller Cycle. This is the strangest motor you will ever read about. The intake valve stays open during the compression stroke...The Supercharger does the compression work. Then the intake valve closes just before fuel & spark. I am currently rebuilding one. It would be a fun project to stuff it into my Mx-3 but I will probably just put it back into the Millenia and sell it.
