Thread: H22 or h23 crank which is stronger ?
    1/4 MILE MOTORSPORTS CEO H23ACCORD-T's Avatar
    DECATUR
    Default H22 or h23 crank which is stronger ?
    im looking into building and im not sure if i should get the h22 crank or not
    Jay, CEO of S.C. Chapter 1/4Mile's Avatar
    Myrtle Beach
    Quote Originally Posted by H23ACCORD-T
    Correct me if i'm wrongbut using a H22 would be de-stroking you engine slightly. Right now you actually have more tq(3 ft0lbs) that a H22 and with boost you would have more tq with the larger displacement. I'm would stay with H23
    "I be on the that Boostanite"
    Senior Member anothaRRR's Avatar
    Gainesville, Ga
    destroke=rev higher....
    i dont know, fonzy can get gangsta, he drives a impala. hes a wife beater and a shotgun away from being Scarface
    as far as STRENGTH of the crank, i would say they are equal. i have never seen a OEM honda crank BREAK or CRACK. OEM cranks make 800+WHP without fail. its the rods that usually fail in the H23 motor.
    If you are looking to build , i would not try to mix and match cranks. use the crank your block was designed to use. IMO
    To 942JZGTE 93H22ACX's Avatar
    spin both to 9500+rpm only if you do it right. bearing failure are the most common with h23vtec hybrids.
    94 Supra= 500rwhp
    Quote Originally Posted by 93H22ACX
    yeah i was gonna say, rod and beargin failure is prob the weak length in the H23 rods, just like the LS rods
    DECATUR
    are there any upgraded bearings or oem will make it
    Gainesville, Ga
    ACL makes race bearings I think...
    yes they do fonzo
    94 Supra= 500rwhp
