Results 1 to 20 of 20
Thread: b18b1 into a 95 civic ex coupe
    Senior Member Schugg's Avatar
    Default b18b1 into a 95 civic ex coupe
    im about to put a b18b1 in my car and i was wanting to know how many qaurts of transmission fluid it will need? and what from my engine will work on it? such as AC compressor hoses, power steering hoses, motor mounts and all that. also will the LS computer i got be able to hook up into my cars inside wiring harness?
    - 1993 Honda Civic VX
    - 2008 Acura TL-S
    you will need a dffrent AC braket i belive... and it should be plug and play if the b18b1 is ODB1 you can use the shift linkage and axels and mounts from the integra.
    good luck
    i got the ac compressor from the b18b1, along with the starter, alternator, intake manifold and all that. also have the bracket i will need. how can i figure out if it is obd1 or obd2?
    - 2008 Acura TL-S
    what year is the LS the car came out of...
    i have no clue, is there a way i can tell from the block code? if not ill ask my friend i got it from, or goto the junkyard that he took the rest of the car too.
    - 2008 Acura TL-S
    Transmission takes 2.5QTS roughly
    ok thanks
    - 2008 Acura TL-S
    Little Red Ridin Hood
    In My House
    look at the block casting
    Decepticons Apache's Avatar
    If it a 94-95 LS motor u r good direct swap... U don't have to worry about OBD.....
    Use parts from ur d16z6 motor as far as brackets and other little things....
    Good luck
    Duppy Rider
    ok he said it is from a 95, so i should be good on that part
    - 2008 Acura TL-S
    yeah, Im still around widecoupe's Avatar
    Columbia, SC
    I did the same swap in my civic. it was very easy. had the d16z out and the b18b in and running within 7 hours.
    if you want to use the ac u will need the ac bracket from a b16 delsol. bout 75 bucks at junkyard.
    Chris Bull
    www.widecoupe.com
    b18b Transplanted, Widebodied '95 Civic
    '05 xB Daily Driver
    Quote Originally Posted by widecoupe
    i dont have ac now, lived without it last summer, i will do without it for a while. why doesnt the b18b1 bracket work?? push the compress to far out or something?
    - 2008 Acura TL-S
    Columbia, SC
    yeah it pushes the compressor to far off the block. u will need the LS transmission mount and rear mount, as well as axles and shift linkage. U can use your stock d16z right side mount ( i polished mine...the mount is solid aluminum). if you have and EX model civic you can plug the wire harness directly into the ecu. The swap was really a sinch...
    if you can bring the motor out from the bottom and bring the LS through the bottom as well. it is so much easier than trying to take it in and out of the top.
    good luck
    Chris Bull
    www.widecoupe.com
    '05 xB Daily Driver
    i have the shift linkage, waiting to get axles, and i have all the motor mounts, may not have the back one, not sure. along with the ls ECU. someone said if i use my normal ecu it doesnt have the same fuel ratios and something like that. im trying to get my friend to take me to the junkyard he took the car to, so i can go get anything else i need.
    - 2008 Acura TL-S
    ........i got my clutch off to change it, and behind the clutch disk, is the pressure place? well it has the 8 bolts close to the center. then the lil bearing in the middle. well the shield fell off the bearing, and i noticed there was a little over half the bearings in it. but they alllll fell out after a while. is there a way i can fix it, or will i have to buy something.
    - 2008 Acura TL-S
    ok i got a question, i have a the obd1 ls motor, harness and ecu. but parts of the wiring harness are cut or ripped. someone said i could you my wiring harness and it would be fine because i have a 95 civic ex. i would just have the vtec plugs extra on it. will my d16 harness work just as good? i heard something about it doesnt and now i have heard it does so i am just checking.
    - 2008 Acura TL-S
    bumfizzzuk, GA
    use the wirng harness form your can is fine you will have to cut and strech some of the wires. yes it works fine i have done this swap in my civic 2 times now and i just put a gsr in it a few weeks ago and i am still using a dx wiring harness. also you will need the rear Vtec delsol mount. if your ls is has the starter and all that than you will not need to buy it; however if your ls does not have these things you will need them also..... it has been about 5 years sence i did the first swap so i may be forgeting some stuff.
    ok thanks
    - 2008 Acura TL-S
    Do you have it up and running now?
    Duppy Rider
    nope, i just now got the garage cleaned up im starting on taking my engine out tonight, so im sure ill be having some questions sometime tonight or tomorrow.
    - 2008 Acura TL-S
