Thread: car paint any help will do
    IA Member tesdaman's Avatar
    Sep 2010
    buford ga
    Default car paint any help will do
    I am going to start painting my car all the paint is still on there should I just take the time and send it or use a stripper to take all the paid off any help or advice for this build will be appreciated
    Jan 2012
    Morrow, Ga
    I suggest sanding it, paint will bond better with a rougher surface, thats just me suggesting lol
    Sep 2010
    buford ga
    Quote Originally Posted by hondagamesik View Post
    I was going to take it down all the way and Ans lay down a new primer
    Quote Originally Posted by tesdaman View Post
    dont, unless there is problems like crows feet..
    Surface Imperfections » DetailingSpot
    Sep 2010
    buford ga
    Okay...so just take off the clear and the paint even though i am changing the color
    Watch some video's, Hard to sit and explain each step that needs to be done.
    It's all about JDM.
    CA to GA
    Use a Dual Action air sander, or a good ole jitter bug sander. Start with 120-180 grit. Break down clear coat to base. Clean with tack cloth and wax grease remover solution. Then rime. Then sand with 200-400 grit. use tack cloth and wax greas remover. Paint base coat, dry and then clear coat it. Let the coats dry in between before layering another coat on top. Better to have a light coat than heavy dripping coat.
    O lord...
    Sep 2010
    buford ga
    Thanks for your help man
    Quote Originally Posted by gsrteg View Post
