Results 1 to 40 of 43
Thread: vtec not kickin in
    lawrenceville and Cartersville
    Default vtec not kickin in
    I have a GSR in a hatch.... and 90% of the time Vtec dont kick in and i dunno if it has somethin to do with it not have a o2 sensor or what but le tme know what it could be?
    NalleyToyota Manager ct9a gsr's Avatar
    Kennesaw, Ga
    Try charging the phone or replacing the batteries. If that fails, we sell some pretty cheap Vtech phones at BestBuy... in case you need a replacement.
    www.toyotaofroswell.com
    Current: '04 S2000
    Past 700whp+ Cars: '03 Z06 | '94 Supra | '03 Evo VIII | Too Many...
    IA.COM Founder.
    Nov 2000
    VTECH will never work bro. I think you got an LS MOTOR y0 ! lol
    vtech in my motor there buddy
    well since when did they start maken b18c1 blocks for GSRs ?
    ls's i mean lol
    oh shittt ... lol i just got that nahh i bought another car thats a 95 with GSR in it lol my fault dont know how to change my name
    Formerly Spyder Man
    Buford, Ga
    Quote Originally Posted by ct9a gsr
    +10
    :boobies:
    VTEC=Variable Valve Timing and Lift Electronic Control
    VTECH= a cordless phone
    DC5-R
    Gwinett
    lol, but yeh have you tried checking your oil level? what ecu are you running? maybe your vtec solenoid isn't holding enough pressure.
    my oil level is good... im not completely sure what ecu im runnin b/c i just bought the car... and i dunno bout the vtec solenoid
    DC5-R
    Gwinett
    Quote Originally Posted by 94LSEG
    look at the top of the ecu located on the passenger side by your right foot
    if you're not running an o2 sensor and a cel is on...you have a few issues to work on first. have you checked codes?
    Slow... mp5o's Avatar
    Is it "lift electronic" or "electronic lift"?
    the original VTEC was "Lift Electronic", although most people miscontrue or change it to "Electronic Lift" cause it sounds better.
    Echinsu Ocha Pher's Avatar
    Apr 2004
    Atlanta/NYC
    Look at the block and make sure it says B18C1... not B18B1
    Marietta, GA
    maybe it's not kicking in cuz you spelled it the wrong way.......j/p
    Curiously Cynical DrivenMind's Avatar
    "when my vtec kicks in it goes ""waaaa waaaaa waaAHHHHHHH""
    -rumplestiltskinbeats
    Quote Originally Posted by estis fatuus
    yeah, that's sounds about right
    check and see if the vtec solenoid has btw 14-30 ohm resistance... or do the click test
    I have a GSR in a hatch.... and 90% of the time Vtech dont kick in and i dunno if it has somethin to do with it not have a o2 sensor or what but le tme know what it could be?
    IVTEC>VTEC
    DC5-R
    Gwinett
    thats how mine sounds because I still have my fukin secondaries, can't wait to get a new IM to replace those.
    Quote Originally Posted by krucial7integra
    you should've heard my C5 with the GS-R P72 ECU...lol, people were like wtf was that?!
    DC5-R
    Gwinett
    c5 runs good on a p72? isn't it going to throw a code because of the butterflies?
    no it didn't run as good as now..it just kicked in really hard for some reason (no CEL at all)...maybe just because it was at the wrong engagement point for the cam lobes. I got a P73 about a month later and the engagement was so much smoother, it's still a big change though.
    DC5-R
    Gwinett
    hmm, speaking of which, could I run a p73 on my gsr? or it wouldn't work at all?
    not with stock internals...the engagement points are differant for a reason...differant cams, etc...just run a piggy back unit like a VAFC or something to play with the fuel, etc...
    DC5-R
    Gwinett
    yeh, did the vafc thing already, not really worth it, rather just get a chipped ecu
    OBD1 or II?
    DC5-R
    Gwinett
    OBD1 or II?
    obd2a I believe, its a 96'....I've used a vtec controller on my last integra (DB2), I think my next step would be uberdata because of all the options it has and money wise.
    Uberdata>VAFC
    Senior Member 99SI's Avatar
    Jackson
    Uberdata requires obd-1. You can not chip an obd-2 ecu. It can be reflashed or a piggyback can be run, but you can not chip it. You would need an ecu from a 93-95 w/ manual or automatic whichever you have.
    DC5-R
    Gwinett
    and you are correct, thats why I was planning to get a obd2-1 conversion from vteckidd and run a p28.
    Jackson
    I gotcha, the way I read your post previously was that you wanted to chip an obd2a ecu from a 96. That's why I posted what I said. Just wanted to make sure you weren't going to go on a never ending search to find out how to chip an obd2 ecu!
    Jackson
    btw, I run a chipped p28 obd2-obd1 conversion in my car. I haven't had any problems whatsoever.
    ....that's exactly why i asked OBD1 or II too
    Senior Member | IA Veteran Speedm0(\)key's Avatar
    Stone mountain GA
    hmm.. i dont know much about VTEC or hondas alone, but could it be like the 2zzge engine problem?.. the lift bolts were wearing down?
    2004 Nissan 350z Trng
    2004 Subaru WRX STi
    solamente los putos te llegan en numeros
    DC5-R
    Gwinett
    lol, sorry for the confusion, but yeh that was my plan but wondering would that fail emissions?
    Jackson
    ^^^absolutely! As long as you have a catalytic converter and can put back on the stock obd2 ecu w/o pulling a CEL then you won't have a problem. The emissions test just plugs into the obd port and reads the ecu, if you are not pulling a code then you will pass, if you are pulling a code then you won't pass. My car wouldn't pass even if I hooked my stock ecu back up b/c I have no cat and a 2.5 inch header back exhaust, not to mention a few other things that would cause a CEL!
    I like ninja midgets
    DC5-R
    Gwinett
    sounds kinda complicated but good thing emissions is only once a year
