Results 1 to 14 of 14
Thread: B18c1 rattle noise HELP
    Rome,Ga
    Default B18c1 rattle noise HELP
    I replaced the headgasket and put everything to spec
    the car doesnt run hot nor smoke
    idles smooth
    but while I'm giving gas I hear a rattle noise sounds like driver side of the engine
    im really not for sure?
    could it be that my timing belt is a little loose???
    also another issue while I'm cruising in 5th gear I go to let off gas and don't clutch it
    feels like the motor jumps are hesitate then I press the gas kinda jerky at the start
    Any help??
    Winder,Ga
    Its your rattle can exhaust..
    It's not the speed that kill's its the sudden stop at the end.
    Rome,Ga
    Quote Originally Posted by masanomi3 View Post
    Yeah right! Let me call skunk 2 and tell them that
    Gtfo the thread noob
    Certified Gearhead YoItsCarlie's Avatar
    Mar 2011
    you deserved a troll. there is no telling where the rattling is coming from. you will need a friend, or at least someone capable of pressing the gas pedal with the car running for yourself to listen for the noise inside the engine bay.
    trouble shooting 101. up close and personal.
    Making it.. one part at a time....
    Mar 2011
    as far as the hesitation goes, check voltage on your o2 sensor, may be getting time to replace.
    VIDEO that shit!!
    Rome,Ga
    It's weird like at idle sounds great when rev and your not moving its almost impossible to hear
    The back side of the timing belt is tight and the front side has play tO it
    Bearing makes a crazy sound, get a clip.. I'll know if it's the tensioner or not.
    knock knock whos there?
    LAWRENCEVILLE
    ROD!
    Hella stock member!
    Duluth, GA
    Quote Originally Posted by silversol View Post
    ROD!
    LMAO
    Feb 2012
    ROD!
    hahahaha, the rattle sounds like its the timing belt tensioner. Same shit happend to me, put my old Honda oem back on and everything is fine.
    Rome,Ga
    Thanks for the input
    I found out had the timing too advance
    Making valves rattle a little
    I redid the timing the motor is running perfect with no sounds
    Thanks again!
    Northwest Georgia
    low oil pressure in head, restrictor missing or oil pump failing. Failing Lost motion assembly would be the best outcome as well.
