Thread: High RPM
    IA Member Mr.Bearclaw's Avatar
    Feb 2012
    Woodland, Ga
    Default High RPM
    Hey, just bought me a 95 Civic EG with a B16A1 engine. Well, I am use to driving diesels and manual trucks. My question is when I am riding down the interstate my RPMs seem to be to high. When I cruise about 80 my RPM are about 4500. Is this normal, and When I try to hit 100 I am about red lining. I just don't know if my RPM are suppose to be this high. If everything is normal then fine, I am just wondering. Thanks. Oh yeah and the tranny is a 5 speed GSR.
    Senior Citizen Dylan's Avatar
    Milledgeville
    That sounds about right. They run high as hell.
    twenty-two
    Milledgeville
    You could try swapping in an ls transmission, they have longer gears and would reduce the rpms at cruising speeds.
    twenty-two
    Feb 2012
    Woodland, Ga
    Sounds good, appreciate it boostedem1.
    Milledgeville
    No problem
    twenty-two
    This is completely normal for gsr/b16/type-r trans, they are geared super short to keep the engine in its power range and not drop out of vtec between gear shifts.
    Feb 2012
    Woodland, Ga
    Sweet, thanks green91
    Pop Clutch and Roll
