Results 1 to 40 of 45
Thread: Forged Performance: Alpha 10 GT-R Pump Gas Record + 957whp C16
    Default Forged Performance: Alpha 10 GT-R Pump Gas Record + 957whp C16
    We've had the pleasure to work on many of Doug's fun project cars over the years, but this one is definitely the pinnacle of his collection. His car made it back down to us from his home in Illinois after only being back in his hands for a few months. His previous 630 whp setup just wasn't enough to satisfy his need for power. He wanted a true street monster that would wax just about anything in its path while still being a civilized daily driver. The heart of the build consisted of an AMS Alpha 10 setup paired with our FP1-R 3.8L in-house assembled power plant capped with a pair of our FP Spec big valve cylinder heads. With these power goals in mind, several areas need to be upgraded including the engine, transmission, brakes, suspension, wheels and tires...the works.
    Many of you recognize our tradition of building balanced track worthy cars that can still be driven daily. When tasked with building a very fast street car, our balanced philosophy is no different. We added a properly sprung set of JRZ RS Pro Silent Edition Coilovers, our Forged Performance Extreme Performance Sway Bar Set with Racing End Links, Endless MX72 brake pads, and a custom spec'd set of 20X10 20X12 HRE wheels wrapped in a square set of Michelin Pilot Super Sport Tires 315/35/20. We even installed a discrete Passport 9500ci radar detector and laser jammer to offer some modicum of protection from the law. The acceleration is neck snapping while the handling remains razor sharp. Our transmission shifts superbly on the upshift and downshift, responding instantaneously to the paddles. There is a lot to be said for a car that not only makes tremendous power, but can also effectively lay it down to the ground and that's what we've accomplished here.
    While we were planning this project, we knew this car was going to be a beast, but we weren't quite prepared for the end result, especially since we consider this a fast spooling balanced daily driven setup. After Sharif worked his magic in front of his Thinkpad, we made an incredible 838 whp @ 24psi on 93 octane on our low reading Dyno Dynamics! Like most shops that use unlinked dyno rollers, we ran the car in 2wd mode in order to preseve the front drive clutches. We were not 100% sure, so we had to confirm with AMS that this was in fact the highest WHP Alpha 10 on 93 octane to date. This car also made 957 whp @ 30psi at 8000rpm on C16 before our dyno gave out. Until we update our dyno software and run larger gauge power cables to the dyno, It appears we are going to have to go to another local dyno to complete the race gas tune on this monster. Stay tuned for updated race gas numbers in the near future! With 5psi left to go, it's no doubt this beast has more room to run.
    Performance Modifications:
    Forged Performance FP1-R Shortblock
    FP Spec ARIAS Extreme Duty Zero Silicon Pistons
    Manley Turbo Tuff I-Beam Rods
    Forged Performance Stage 5 Ported and Polished Heads and Bronze Valve Guides
    Tomei 272/272 ProCams VR38 Camshafts
    Ferrea VR38 Full Valvetrain Kit w/ 1mm Oversized Valves
    ARP L19 Head and Main Studs
    HKS Head Gasket
    AMS Alpha 10 Turbo Kit
    AMS GT-R FMIC Kit
    AMS GT-R Alpha IC Piping kit
    Injector Dynamic 2000cc injectors
    T1 Race Development Fuel Rails
    FP Spec Fuel System with -8 Line Upgrade
    CBRD Radiator
    GTC 102mm Titan Exhaust & Y Pipe
    PPG 1st Gear
    FP Spec Stage 4 Dodson GR6 Upgrade Package (Promax Clutch, PPG 1st gear)
    Transmission Assembly and Overhaul Performed In House at Forged
    Cobb AccessPort w/ TCM
    Other Upgrades:
    Password JDM 38mm Wide Front Fenders
    HRE P40 20x10.5/20x12 Flat Black
    Michelin Pilot Super Sport 315/35/20
    Escort 9500CI Laser Shifter & Radar Detector Kit
    Forged Performance Racing Stainless Steel Brake Line Kit
    OS Giken Rear TCD Differential
    Pictures of the work:
    93 Octane:
    C16 Racegas:
    ATL, GA
    damn thats badass...0-60 in sub 2 seconds? lol
    Quote Originally Posted by RL... View Post
    Traction is an issue to say the least, we have a set of 18 inch TE37SL's and drag radials and with that we should expect 0-60 in the low 2 second range.
    May I ask why Sharif disconnected the front diff when tuning it?
    Certified Gearhead jtdb8's Avatar
    Oct 2011
    where everybody knows everybody
    That is a sweet sweet ride. AND SOME SICK POWER. that car will be stupid fast. Props to you and forged chad.
    1-UP!
    Certified Gearhead dc2gs's Avatar
    Oct 2011
    cartersville
    Thats is SICK!!! great work dude
    Macon, GA
    that is so bad ass...
    Quote Originally Posted by MeFryRice View Post
    The front clutches on the GT-R have a tendency to overheat when you do 30+ back to back pulls on a dyno. To preserve them most shops dyno tune the car this way once you start getting in the 700+ WHP range. Once the car is on the street or track this isn't an issue, but on the dyno it is just a safety measure.
    Chad? Is this car supposed to be impressive, dammit? Later, QD.
    Quote Originally Posted by Chadbee@Forged View Post
    Any numbers based on the power going to all four wheels?
    Chad? Is this car supposed to be impressive? Later, QD.
    It's not supposed to be, it is. You're not ignorant so I'm sure you know 850+ WHP on pump gas, low 9 second capable drag times and the reliability to drive cross country is not an easy task.
    Dahlonega
    must be nice to have some extra cash...
    looks nice...
    You know I'm not ignorant. You should know I was joking, though, Sir Chad! Later, QD.
    Well, the GT-R's drive system is RWD on the street until it senses a loss of traction then it converts to AWD to help split the power. I have driven a 704 WHP GT-R with the front driveshaft removed and from 60mph it hooked and pulled hard with zero wheel spin. If that car still had the front driveshaft, it wouldn't have been powering the front wheels in that situation so it being RWD on the dyno is a very accurate. The GT-R's AWD system is a lot more advanced than say, and Evo or STI, it only uses the front wheels when it is needed. Also the drivetrain loss to the pavement is a lot less than most AWD cars as well.
    Just to go a little more in depth regarding the reasons we typically tune higher HP GT-R's in RWD mode, the front drive clutches are perfectly happy driving the front wheels as long as the front and rear rollers are working and locked together, just like they would work on a public road. On an un-linked dyno system such as the Dyno Dynamics, or DynoJet, running the car in 4WD mode means the front drive system is spinning up the front roller without help from the rear. This would be like standing the car on it's nose and accelerating it down the street. AMS, Shep, and pretty much all the tuners agree on this. We are working on a custom modification to our dyno, where we will link the rollers together. For extended tuning sessions, it's simply a lower risk approach to disable the front drive. This would make our life much easier as R/R'ing front shaft gets old. Keep in mind, we only do this on builds that approach 700whp and beyond. For stock turbo setups we feel the risks are minimal and continue using the dyno in 4WD mode.
    Thanks for the questions Steve, come out to C&O this weekend and check it out in person.
    JDMSK8R JEY$JDM's Avatar
    NY 2 GA
    Hell yeah man... Goooood sh!t like always! Can I come to work with yall?! lol
    Quote Originally Posted by JEY$JDM View Post
    Hah! We aren't hiring right now but if something comes up I'll let ya know.
    NY 2 GA
    Shweeeeeeeet haha
    Thanks for the clarification. I forgot about C&O this weekend. We'll make it up this month as she's (the gf) worked every last Sunday and would enjoy coming out again
    No problem at all, I'm always happy to answer any questions and if I don't have a informed answer I'll ask Ryan or Sharif lol Awesome, find/call/text me when you get there Don't forget there is a new location:
    5310 Windward Parkway
    Alpharetta, GA 30004
    sick
    Kennesaw, GA
    Forged moved up to windward? I guess I'll be seeing a lot more of these cars now. Lol
    NIKON Squad member 01
    OF*C
    OEMFitment Crew Memeber 01
    Quote Originally Posted by .blank cd View Post
    Both our locations are still on Cobb Parkway. The Caffeine and Octane's new location in on Windward.
    Kennesaw, GA
    Ahhhhh
    OF*C
    Senior Citizen Dylan's Avatar
    Milledgeville
    Get paid to do something you enjoy, and you will never work another day in your life. Forged kicks ass, I'm sure every day at work is amazing!
    twenty-two
    wherever
    Meh....I could take it.......
    ...out with a hit from a Mack truck lol.
    I hear there is a Veyron in town talking shit about GT-Rs.....
    02' Miata
    PLEASE get me in touch with the Veyron owner! That is a video you will want to see right?!?!
    This cars 60-130 SHOULD be in the LOW 4 second range.....a stock Veyron is 5.6.....a y-pipe + tune GT-R is around mid 8 seconds.....a stock 430 is 10.1
    wherever
    Chad...dude...I was joking with you lol. I have yet to see one in Atlanta (though I've heard rumors of a couple being here). I was also implying that this car could put up one hell of a fight...so much that I couldn't really give my opinion on who would win.
    02' Miata
    Oh you tease! I have heard of a few running around and hoping you were serious lol this car would WALK a Veyron(yes I am bench racing lol). The new Veyron SS claims 9.9 1/4 mile and GT-R's with similar power as this one typically run 9.1-9.3.
    Real track numbers on 18" TE37 and drag radials soon
    Ummmmmmm......Damn, that's pretty freakin awesome. Also i didn't know that GTRs ran on 2 wheels, til they slipped (THE MORE YOU KNOOOW!)
    BUILT NOT BOUGHT .........
    Yeah the R35 GT-R's drive system is insanely intelligent! This is just one of the many things that allow the car to use its power so effectively.
    Certified Gearhead AtlScionBoy's Avatar
    Jan 2012
    now thats sex on wheels!!
    Kennesaw, GA
    Chad, did you do the video?
    OF*C
    Come at me .... ZOSICK's Avatar
    Apr 2011
    Chad if one wanted to duplicate This build what would it cost car included? thx
    C6 Z51 FORGED & STROKED BUILT BY LWA OUT DOIN WORK
    Oct 2010
    is this the one from Macon?
    Quote Originally Posted by JoshRuff View Post
    I take it you haven't read a thing?
    zoom-zoom-zoom
    Oct 2010
    just a simple question, dont have to be a smart ass about it.
    EX Super Mod TIGERJC's Avatar
    Fayetteville
    Since we're bench racing, it might be closer from a roll going up to 200 mph http://www.youtube.com/watch?v=Qgm2t...feature=fvwrel
    2006 Evo IX - Bolt ons
    Quote Originally Posted by AtlScionBoy View Post
    Ha I agree.
    I did. I'm trying to get better.
    Quote Originally Posted by ZOSICK View Post
    For obvious reasons we don't release exact information on the cost of customers builds but for a fully built 1000-ish WHP GT-R you going to spend roughly:
    $65k-ish for a nice 2009 GT-R
    $80k-ish for the motor/head/trans/turbo build
    then you want good suspension which would run around $5-7k, brakes for $3-4k, wheels are tires for like $6-8k
    It is far from cheap but then again the end result is a supercar killer that runs low 9's, handles extremely well, has the braking capabilities to bruise your shoulders(happened to me at the tail of the dragon) all while keeping your butt warm in the winter and having navigation incase you get lost.
    No.
    Quote Originally Posted by TIGERJC View Post
    To my surprise the GT-R still pulls hard up top, unlike other AWD cars. Using a black box to record 60mph-130mph times is a big deal these days. Check out those times using google, very interesting stuff.
    Dragtimes car is a Switzer P800 kit, which puts down about 700whp on our dyno....which is 250whp less than this car.
    ...and stop being a stranger, call me when you have time.
    Apr 2011
    Wow that crazy!
