Results 1 to 26 of 26
Thread: wtb: Eperienced Mechanic for 93 civic labor ASAP!!
    Certified Gearhead jdmda9's Avatar
    Default wtb: Eperienced Mechanic for 93 civic labor ASAP!!
    nm,
    shhh...
    vtec game scArY. . !
    Aug 2009
    What's wrong with it?
    I put in a new swap and outta no where whenever I try to start the car, the cluster lights glitch like they begin to blink on and off swiftly. The harness inside the cabin and in the motor is perfect I just don't know what the hell is going on. It rarely has its moments where the cluster lights come on correctly that only happened like twice and even then the motor would just rotate but not start. It had the ignition coil cel code but I haven't changed it out because I can't even get the lights on the cluster from glitching any longer.
    shhh...
    ANY MECHANIC WHO THINKS THEY COULD RESOLVE THIS PROB COME BY AND Give it your best try, it wont hurt me to spot out someone a few bucks for gas but I really would like to get this thing fixed before anything!! I think the car just needs a new inner fuse box but idk, any help would be greatly appreciated!
    shhh...
    Dec 2008
    Northside
    GROUND. so ur just trying to fix the lights from glitching?
    11.3 @ 117
    Midnight
    Auto
    M
    ORRIS TUNING
    center field
    his car wont start ............ the lights just flicker every now and then......he wants the car to run .......
    Privateer Racing!!
    Duluth,Ga
    Let me go to Long Horn and order a steak and taste it, then I'll decied if I want to pay for it or not.
    Aug 2009
    Quote Originally Posted by B18c1Turboed View Post
    ^^ this
    Where are you located? What swap did you do? what harnesses did you use? I guarantee I can fix it, I just am not coming to fix it for pennies.
    so your telling me that if you were in my situation and some random dude called. stating that he worked for honda, is ase certified blah blah blah and then he comes and has a look at the car. next thing you know, hes just gonna look over and say "idk man, this car just seems raggedy. i dont think i can fix it, looks like you just need a whole new harness. but i still want my money for coming way out here." notice i said EXPERIENCED if your not confident in your skills, then dont bother wasting my time or yours. because really i could give a shyt about 30 bucks for gas, but i wont let you make me look like an ass, or hand em over that easyily to some idiot who wouldve told me some bs that i wouldve already known! p.s. both engine and cabin harness's appear perfect. no exposed wires, mis-wired, fried, etc. you get the point right?
    shhh...
    i bought the car as just the body aka shell. its a 93 civic, so i put in a single cam swap( d16z6) the first time and everything seemed to be running perfectly about. not even one cel code on a stock p28. then, i turn around and drop in a b series vtec swap and out of no where when i try to crank the motor for the first time, the glitching effect takes place on the cluster as mentioned.
    *i used the same obd1 vtec harness off my single cam and im still running the same p28 ecu as well. i didnt even mess with any wiring besides unplugging the engine harness from one motor and transfering it to the other one throughout all this. i dont consider my self a honda guru, but i know what im doing as far as anything basic like swaps, maintenance, etc. i just cant seem to figure this out. i already swapped ecu's and still nothing. EMMINO IF YOUR DOWN TO FIX THIS POS, CONTACT ME ASAP: 404-556-1806
    shhh...
    LAWRENCEVILLE
    Whats it worth to you?
    Hella stock member!
    Quote Originally Posted by silversol View Post
    150 max, honestly it seems like an easy fix i just need someone to inspect it and see whats going on. for 200 i can buy all new cabin and engine harness's and re-wire the whole thing like stock.
    shhh...
    Aug 2009
    Lol $150 will worth about an hours of diagnostic.
    How much are yOu willing to pay to get it fix.
    Feb 2010
    A-town
    This is funny....
    No one is gonna help u bro unless they just want to. Any person that is experienced is not gonna waste their time accommodating u to make 1.6 hours worth of labor. Im sure their are people that could help u and use the money but depending on where u stay they aint gonna drive out there. Usually u get the car towed to a shop u trust and they fix it. Not trying to bash u but u are better off just asking for the help. cause its making u look like "hey come help me, but only if u know your shit". "and even if u do know your shit I don't plan to pay if it aint fixed"
    THE CLEANEST DA in GA
    Like I said experienced personnel(s) ONLLLYYYY! I can't stress that one worded, meaningful, simple fact of a statement enough for you people to understand. I don't have a trailor, obviously this is one of my alternatives as in terms of fixing my car, that's why I created this post. In hopes of finding some help. As I can clearly see this is a waste of time. And why pay 400 plus when I can go to my local junk yard, invest 300 tops anld be about my business.
    shhh...
    Aug 2009
    They you should go to the junk yard to buy you another junk part. Shop charge about $100 buck an hour to do the work. But in your case, you nor the experience car expert have yet to find the source of the problem. Ain't no blow Joe even gona waste he time to drive to you and fix it for that price.
    Look, if you find out what wrong and buy the parts. I will come and tight the bolt for $150.
    Privateer Racing!!
    Duluth,Ga
    Get the car towed to a shop and hope they can find the problem for you. If not they still charge you their hourly rate.
    But serious check all your grounds and make sure everything is plugged up fine. That nothing is loosin connection.
    Twan Jdm94Coupe's Avatar
    Fairburn
    Call barefoot.
    GE8 RS
    its funny to me how ur so sure u can spend 200-300 at a junk yard and "be on your way" with it. if its that easy then y pay someone to go out there to tell u its the harness, then have to buy one in the end anyways, and pay him to install it? wen ur smart enough to do it ur self. from a technicians stand point this is a waste of time.
    its even worse not knowing the condition os the car. it could end up lookin like a pile of shit with endless amounts of problems. theres no telling what kinda problems the shell had wen u bought it. $150 to chase my ass around looking for whats wrong with ur car is not worth it. tow it to a dealer or a shop and dont worry bout it have hope some one will fix it because its xmas and they feel like giving.
    good luck tho. hope u get it fixed.
    i dont know how many times i gotta tell you but its your grounds. check them all and be on your merry way.
    i pray for some of you lmao!!!!
    shhh...
    Quote Originally Posted by Austin? View Post
    aghhahahahahaha.
    shhh...
    Aug 2009
    Quote Originally Posted by jdmda9 View Post
    aghhahahahahaha.
    Thats exactly what I did when I read you first post. Lol
    And Thanks for thinking about me when yOure praying.
    IA MEMBER turbob20's Avatar
    LaFayette Ga.
    just check to see if the ground from the harness on the engine is grounded to the thermostat housing and if it is make sure its not broken,damaged ect. this is the main ground for ecu and everything.
