Results 1 to 13 of 13
Thread: New project, few questions
    Woodstock
    Default New project, few questions
    I am working on building a boosted D series. I am not buying any ebay parts and trying to make it reliable as possible. Power numbers should be around 300+/- to the wheels. My question is when should the transmission be beefed up? Will the trans hold up at these power numbers, with only a clutch and flywheel? If it needs to be beefed up where is a good place to have it done?
    setup will be....
    D16Y8
    Turbo- Precision 4831B .63 a/r
    GO-Autoworks Cast manifold
    Tial 38mm WG
    HKS SSQV BOV
    FMIC 2.5 piping
    Full 3" turbo back exhaust
    750cc RC injectors
    Walbro 255
    RCautoworks custom d16 rods and vitara pistons(75.5mm)
    Comp Clutch stage 4
    Comp Clutch 9lb flywheel
    Tuned on chrome
    any input would be greatly apprenticed.
    All I know about D series trannies is that the automatics blow up at 200whp. Constantly.
    If you have the money, d2b might be a nice idea.
    Woodstock
    haven't really thought of that, thanks.
    Woodstock
    Anyone else have any input? Trying to do this right, but don't wanna change the transmission if it's not needed.
    Loganville
    Don't forget ARP headstuds
    Ballin' on a Budget
    Woodstock
    Quote Originally Posted by carbon_crash View Post
    yeah they come with the piston/rod combo.....from RCAutoworks.
    Trans will be fine at 300whp. Ive only ever had the ISB fail, but idk what the mileage was on the trans. It had been well abused. You'll want a LSD though.
    Loganville
    O.P.- are you going to build the bottom end and run a stock head?
    Ballin' on a Budget
    Woodstock
    Depends, how my wallet feels after list above. Bisimoto 2.4 cam is possible with valve train of course.
    Here is my suggestion
    Get the custom length rods, or the vitara's are going to suck big dick. The compression sucks with stock length eagles, and makes for a laggy, not much throttle response type engine.
    I recently built a custom rod/ vitara for a customer and it made 255 @ 14 psi, on stock head.
    The trans itself will hold, but depending on your driving you may break a diff, or rip teeth off the ring gear on wheel hop situations.
    You will need a 3 bar map sensor, a boost controller etc...
    Woodstock
    On the site it says custom length rods, 9:1 CR...My civic w/ LS swap made 250whp with an ebay kit, I was happy with that power level...just had too many issues with compressor surge, BOV sticking, etc. I know I need the MAP sensor and a manual boost controller is on the list also. A lot of little stuff that I need that not listed above...motor mounts, boost gauge, etc.
    I've got a glowshift boost gauge and an HKS EVC5 boost controller for sale if you're interested. $20 and $300.
    Senior Member JDMJ's Avatar
    Jun 2009
    Cedar Bluff, Alabama
    Yeah, trans will be fine at 300whp. LSD is always a plus though.. i made 280/206 and loved it.
    Sig too big
    -IA Management
    Originally Posted by tnomud
    Aren't all IA HOndas 11-12 second cars?
