Results 1 to 18 of 18
Thread: need help choosing between jdm f20b or jdm h22a
    Default need help choosing between jdm f20b or jdm h22a
    I need help choosing between these two motors the DOHC f20b from the sir-t( the one with type s valvetrain and cams) or jdm h22a for just a daily with bolt ons. Is there any differences between them, except the displacement and what the cylinder walls are made of? are all the parts interchangeable? sorry im in a rush and will add on more later.
    McDonough
    Parts shouldn't be interchangeable. I'd go with the H22 simply for it's aftermarket abundance and ease of replacement parts.
    Bitches love bacon.
    Southern Speed
    Macon
    Alot of parts are interchangable. The Pros to a f20b is iron sleeves, type s VT and cams, can rev to 9k factory. Cons are smaller valves( i think) less stroke and bore.
    McDonough
    Previous statement retracted.
    Wasn't aware of the similarities.
    Bitches love bacon.
    SOUTHERN SPEED
    macon ga
    Parts are interchangable man. F20b comes with type s cams and type s valve train which is worth as much as the motor is . You could blew it up part out the head and not lose one dime lol. It has 85mm pistons and imm smaller intale valves . It also has 11.1 compression from the factory and iron sleeves . It has the new style lmas and 55mm main bearings. Motor is built to take a beating. Mine ran 13.5 bone stock in a heavy si hatch. All my h22 ran 13.5 bone stock in the same hatch . Only difference is tourqe.
    The h22 has a 87mm bore and frm sleeves. You cant run forged pistons in the frm sleeves but they run cooler and last for ever . Mahle pistons work great and are good to around 400hp. The h22 has imm over sized intake valves from the f20b and the actual combustion chamber is wider for the 87mm bore.
    It all comes down to what you wanting to do and what your goals are . If youn tell me that i can tell you which one better suites you and why . Honestly for the money and better power down the road the h23 vtec is the best bang for the buck right now . Check up on it.
    252plus hp and 34.5 miles to the gallon all motor. 12.2 at 111
    Southside Ridin HATCH
    YEP. Had a F20B in my garage. Never put it to use. WISH I DID. They are Nice!
    Anyways got rid of it, to the man posted above me.
    to h22 jones
    i just want a daily with bolt ons and maaybe some cams later on the road and thats it, dont wanna touch the bottom end. but ive read some of your posts that you can run more aggressive cams on type s valve train and so if that is true i just wanted to throw some cams on the f20b. i would love to go with the h23a vtec but unfortanatly they are out of stock on hmotors. trying to get a motor in two weeks
    oh and this is going to be with a QSD kit with b16 tranny
    SOUTHERN SPEED
    macon ga
    I would be real curious to see what a f20b ran with a b series tranny . Make sure you get a five speed motor . The auto motors cost alot less but they dont have type s cams or valve train .
    McDonough
    Quote Originally Posted by Infamous_1 View Post
    to h22 jones
    Tiger Japanese has them all day long for $1006 shipped to your door. Placed the order for mine on a Monday, order processed on Tuesday, and picked it up Friday the same week.
    Bitches love bacon.
    i heard bad things about tigerjap...so im just gonna order from hmotors
    im not really sure which motor to get...its also gonna be in a integra
    McDonough
    I've heard bad things about HMO It's all your choice. I am happy so far with what I have and will probably order from TJ again.
    Bitches love bacon.
    Quote Originally Posted by h22 jones View Post
    guess i will look into the h23 vtec..maybe go with this route
    hopefully i dont get a bad motor..
    that would prolly be a very fun setup to drive.
    never heard one bad thing about hmotorsonline. are you sure youre talking about the same place? My H22 came from them, i am not even the original owner, beat the piss out of this thing for about 5 years now, and while I have had a couple scares where I thought something was wrong with it, it always tunred out to be something else.
    Quote Originally Posted by Apex1972 View Post
    i might just go with torontojdm 1105 shipped for h23a vtec
    now youre talkin.
