Results 1 to 13 of 13
Thread: 1992 INTEGRA HELP
    FREE BUJU StarBwoy's Avatar
    IDK
    Default 1992 INTEGRA HELP
    OK I HAVE A 1992 INTEGRA I PUT A FUEL PUMP IN AND STARTED IT AND IT RAN BUT IT NEED A AXEL HAD THE CAR IN THE GARGAGE FOR LIKE 2 MONTH THEN I BOUGHT THE AXEL .BEFORE I PUT IT IN I PAINT THE MOTOR AND ALL THE GROUNDS STUPID IDEA BUT I SCRAP THEN OFF . PUT THE AXEL IN AND SUM MORE GAS TRY TO START THE CAR AND ALL I HEAR IS A CLICKING NOISE COMING FROM THE DASH NOT THE STARTER. AND THE FUEL PUMP IS NOT COMING ON NEED HELP and i have a good fuel relay
    IT HAS A NEW ECU AND DIZZY NEED HELP ASAP THANKS IA
    DA SQUAD MEMBER #90
    AWOAH
    [SIGPIC][/SIGPIC]
    main relay
    I would take the main relay out and take it apart and look very close to all the solider points and re solider them if cracked .Very simple fix I do it all the time never once bought a relay in my life .
    IDK
    i forgot to tell yall the main relay works its clicking took it out of a running car
    DA SQUAD MEMBER #90
    AWOAH
    [SIGPIC][/SIGPIC]
    check your fuses an is there a alarm on the car?
    Rome,Ga
    Bad ground check thermostate housing ground off ur harness
    IDK
    Quote Originally Posted by Tech5 View Post
    i did all goood and i think there was
    Quote Originally Posted by terrytowe22 View Post
    the ground is not hook up its on the starter
    DA SQUAD MEMBER #90
    AWOAH
    [SIGPIC][/SIGPIC]
    Rome,Ga
    That's a prob there is a engine harness ground put it on the water neck
    IA MEMBER turbob20's Avatar
    LaFayette Ga.
    strip all paint off where the bottom radiator hose goes to block. there is a bolt hole on top next to the thermostat housing that the hose is on scrape it good and put your ground harness that runs in your main engine harness on it! this grounds your ecu and stuff!
    IDK
    would it help that the car has a wire tuck but i went though the wires and there all good but ima do wat he said ^ and hit yall back
    DA SQUAD MEMBER #90
    AWOAH
    [SIGPIC][/SIGPIC]
    IDK
    does that harnes with the grounds on the thermostat is iy for the pump too ?
    DA SQUAD MEMBER #90
    AWOAH
    [SIGPIC][/SIGPIC]
    LaFayette Ga.
    Quote Originally Posted by StarBwoy View Post
    it grounds ecu,main relay and stuff! if the main relay doesnt work your ecu has no power either!
    LaFayette Ga.
    if the wires were just taped and not soldered properly then thy can corrode and lose connection!
