Thread: b16 slow rev problem
    IA Member HolleyStyle's Avatar
    Jun 2010
    T-Town, Georgia
    Default b16 slow rev problem
    just put a b16a into a 99 civic, got as tps code, ive tried to check it and the voltage is way high, so i put a new one on it and it does the same thing. but the problem is that it revs really slowly, any opinions as to what else i should be checking or is the tps what would be causing this problem
    They call me Gator...
    =) JF868849's Avatar
    Oct 2008
    BYRON
    Check the timing
    h22?
    barrow county
    i believe the tps and map plug is interchangeable. make sure it isnt mixed up also.
    IA MEMBER turbob20's Avatar
    LaFayette Ga.
    x2 on the plugs!
    flywheel is too heavy
    TPS and MAP plugs are incorrect, timing is off, or ECU is bad.. im sure there is a CEL, check it and post the code.
    Rome,Ga
    Can't u adjust the tps sensor?
    Quote Originally Posted by terrytowe22 View Post
    you can, but even a TPS sensor adjusted VERY wrong wont make a car rev THAT slow... only it being backwards or mix-matched plugs would do that.
    now that i think about it, im assuming you are going from a D16y7 to a B16? if you are and you are using the original D16y7 engine harness, swap the 2 OUTER wires on the TPS plug... D16y7 throttle bodies use a backwards sensor. Although, if your coming from a D16y8 then disregard what i just posted LOLOL
