Results 1 to 5 of 5
Thread: Single Cam Starter PROBLEM
    Sohc Me Beautiful geezy's Avatar
    With Your Mom
    Default Single Cam Starter PROBLEM
    so this week i got off to eat.. once i came back my car didnt wanna start... so we did the pushed trick and it started..... everyone told me it was the starter so i bought a new starter, and still dont turn on... i checked battery. its good. cables and fuses and still dont turn on.. it dont make ANY clickin noise. it basicly dont make ANY noise at all but i can hear my gas pump turn on... What could this problem be??
    key switch maybe???
    Projects
    Check the starter relay since it sounds like no juice is getting to the starter itself.
    West Ga
    basic but check your fueses also...
    Safety neutral switch is bad... Look on clutch pedal, unplug it and put a jumper wire.. If it starts then replace the switch..
    Also:
    2. Ignition switch, but normally it will lose dash lights or all power if that is bad..
    3. Check ground on the tranny to frame rail..
    4. be sure the single wire to starter is good, the little wire.. check for 12v with key in start position..
    del sol? 94_teg_ls's Avatar
    Quote Originally Posted by 1civic View Post
    Also:
    yeah we had that issue the other day with the ek
    /sig
