Page 1 of 4 1234 LastLast
Results 1 to 40 of 136
Thread: D16 Mild Build. 92 Civic Cx
    Twan Jdm94Coupe's Avatar
    Fairburn
    Default D16 Build. 98 Civic Cx
    I'm starting a new thread because my old one no longer applies. But just to give you a little background info...... i got the car around 16 months ago and I had a lot of set backs, and I will show you all the old pics all the way up until the way it sits today. Starting with the bottom end rebuild in march of 2010
    Fairburn
    Last years disaster. I didnt install my catch can in time and had a small setback, lol..... pics
    pulled the motor.... and u can see what i see! lol
    Fairburn
    opened the motor and this is what i found, lol
    Fairburn
    more destruction pics......
    Fairburn
    here are some shots of old parts that i replaced and decided to change some stuff around at the same time as the build.....
    Fairburn
    a few more......
    wheels, beaks, blox, benen all sold.... rather quick i might add, lol
    bought some drag radials, and then sold them, lol
    Fairburn
    ..... then some red lug nuts because i was gonna do these wheels and a red beaks bar, but i sold the nuts too and changed my plan again....LOL
    Fairburn
    Default Rebuild Time
    D16Y7 Bottom End
    76MM Vitara Pistons
    Hastings Piston Rings
    FJ Custom Length Rods
    D16Y8 Micropolished Crank
    ARP Head Studs
    OEM Oil pump purchased from FJ's website
    Blox Magnetic Drain Plugs
    Go Autoworks Low Temp thermostat
    Go Autoworks Block plug adapter
    Fairburn
    Fairburn
    Fairburn
    a few shots as i put it back together, only 2 decide that i wanted more power......lmao
    precision 650cc high imp injectors.....
    Fairburn
    stock cylinder head.......
    Fairburn
    here's some pictures of the turbo before i rebuilt it..... my original drain was not big enough so i messed up the seals. and i upgraded my drain now..... heres all the pics of the turbo. before rebuild and after......
    Fairburn
    Fairburn
    replacement parts.......
    Fairburn
    yes my toes r in the picture, lol
    Fairburn
    Fairburn
    Fairburn
    some more old pics before i rebuilt my turbo...... thats a friend of min's hand in the pic.... he's got a b16 and is a active d16 hater.....
    Fairburn
    these are also before my catch can...
    downpipe.....
    my horrible brakes. lol
    stainless steel lines from tank to rail.....
    Fairburn
    after the catch can install...... the first time, lol
    Fairburn
    when i rebuilt the turbo.......
    here's a few pics of the turbo........
    Senior Citizen Dylan's Avatar
    Milledgeville
    dam hail fcuk yeh! d16 ftw!!
    Fairburn
    Default update
    As of right now here is everything I have sold to make room for the new goodies....
    SOLD:
    Ebay Cast Manifold
    51 Trim Garrett .60 comp/.58 turbine w/ internal wastegate
    2.5" Downpipe
    Go Autoworks Intercooler Piping
    Emusa Intercooler
    Stock D16Z6 Cylinder Head
    2.5 Full vband exhaust w/ vibrant 2.5" Stealth Muffler
    Fairburn
    this is what I got to replace the stock cylinder head.....
    Fairburn
    more.....
    Fairburn
    even more.....
    Fairburn
    clutch was slipping on JJ's dyno so I had to upgrade.....
    small update. more 2 come soon........... out with the old spec 6 puck in w/ the competition clutch stage 5 ......4 puck
    Fairburn
    random pics......
    Fairburn
    more randomness.....
    Sep 2003
    Looks good man! What kinda duckbill did you get? It looks to have some decent kick to it.
    Fairburn
    Quote Originally Posted by 5spdfrk View Post
    ebay ftw
    Fairburn
    Default Parts List
    Here is a updated list of engine mods.......
    D16Y7 Bottom End
    76MM Vitara Pistons
    Hastings Rings
    D16Y8 Crank
    Performance Porting Stage 5 Ported/Polished D16Z6 Cylinder Head...... intake and exhaust
    Supertech Valve Springs/Retainers
    Bisimoto 3.6 Turbo Camshaft
    Bisimoto Cam Gear
    New OEM Honda Y7 Oil pump
    Competition Clutch Stage 5 Clutch
    Stock Flywheel
    D16Z6 Tranny
    Precision 650CC Injectors...... SOLD
    Vband 2.5" Full exhaust w/ vibrant stealth muffler........... SOLD
    Walbro 255 Fuel Pump
    Go Autoworks Stainless Steel Line from Tank to Rail
    AEM Fuel Filter
    Thermal IM Gasket
    Golden Eagle Fuel Rail
    AEM FPR
    ARP Headstuds
    D16Z6 STOCK cylinder head.......... SOLD
    Blox Intake Manifold
    LS Integra Throttle Body
    Ebay Cast Manifold
    Garrett turbo .60 comp/.58 exhaust
    Emusa Intercooler
    HKS BOV
    ............ ALL SOLD
    Blox Boost Controller
    lawrenceville,ga
    nice build
    Certified Gearhead YoItsCarlie's Avatar
    Mar 2011
    What are you plaaning for as far as engine management? and why was the waste gate blocked off on the ebay cast mani?
    Fairburn
    Quote Originally Posted by jdm eg6 View Post
    nice build
    thanks man, reps.......
    Quote Originally Posted by YoItsCarlie View Post
    I'll probably be on crome until i sleeve a bottom end and do d2b conversion......... but 4 now i'll stick w/ crome pro........ and the wastegate was blocked off on my old ebay manifold because my turbo was built w/ a internal wastagate...... no need for external for my old power goals IMO, and it looks a little less congested......
    It cost like 10 Buks to turn a Flywheel.. Just sayin
    Certified Gearhead DA9_Vito's Avatar
    Dec 2009
    Forsyth,GA
    Quote Originally Posted by 1civic View Post
    ^this. cause from the way that flywheel was lookin and say turn it or go light weight lol. on build man.
    Privateer Racing!!
    Duluth,Ga
    Looks good man
    Fairburn
    no need sir...... d2b will come soon..... this will take me through the end of the year. plus i already committed on doing it that day and had a friend come down from kennesaw to help....... have no fear, even with the flywheel looking like that i will bring fear into the hearts of most b series owners, lmao
    Quote Originally Posted by DA9_Vito View Post
    lightweight will not benefit me, but thanks 4 the love.......
    Quote Originally Posted by B18c1Turboed View Post
    Looks good man
    preciate it homie, maybe one day i'll be on your level, lol......
