Thread: Turbo D-series clutch
    ATH GA. SRCRX's Avatar
    On the drum set!!
    Default Turbo D-series clutch
    I just got a 97 civic hatch, It came turdo'd already, I've had it about 2 mo. or so,
    knowing that is was a mod. used car I knew that some things were going to have
    changed/fixed.
    So the clutch is starting to die, I'm guessing that I need one that will hold up
    to around 300hp.
    I plan to re-tune it, after some upgrades, what's why I'm thinking 300
    From the dyno sheet it put down right under 200HP, and from info. that came with the car it had a clutch put in last summer, and its already going out, I do not want to tell the brand of the clutch as some might affiliated with them.
    Not to be rude but, if you have never had to deal with a problem like this
    please do not add your 2 cents!!
    Competition clutch has never failed me and I've always been pleased with the performance. You'll probably want to run around a stage 3 sprung kit for the type of power your aiming for. You could call them up as well to see what they would recommend for you.
    91 CRX SOHC-550WHP 420TQ (Sold)
    02 WRX-224.4WHP 223.2TQ (Traded)
    01 S2000 (stock)-201WHP 130TQ (Traded)
    98 GSR (stock block) - 415WHP 340TQ...Hydro locked. Sigh
    91 240SX POS - 0 WHP 0 TQ (Junked)
    10 370Z (Sold)
    97 Civic DX (turd awaiting polish)
    98 GSR (built) - 606WHP 366TQ @ 20 psi on 93 octane
    Stang Mod slostang's Avatar
    Southside
    I had a competition stage 2 in my turbo'd EF and loved it. Stage 2 is plenty for a stock motor with a turbo setup, if you're planning on building it you may wanna look at a stage 3. You dont want TOO much clutch.
    On the drum set!!
    Thanks guys, Why would I not want to much clutch, you mean
    As far as the pedal feel?
    Middle, Ga
    Quote Originally Posted by SRCRX View Post
    Exactly, You don't wanna be driving in city traffic all day (especially if you live in Atlanta or other highly populated areas) with a really stiff clutch if its a DD. Unless you have super human legs that never get tired. lol.
    "Damn, Its Tyler"
    RaceReadyDevelopments
    On the drum set!!
    Quote Originally Posted by FasTech View Post
    LoL, anyone else with any input??
    x2
    thanks to my stage 4 my left leg gets a great work out during traffic... it doesn't help the fact that its a cable tranny either lol
    10 370Z (Sold)
    stay away from SPEC..I have a SPEC stage 3 on my boosted accord and its horrible..so loud and harsh..pedal is very soft.
    Im going with the ACT Heavy duty kit in a few weeks..rated for 286ish tq.
    Southside
    ^^ what he said. Plus the stronger the clutch is, the life of the clutch decreases.
    On the drum set!!
    Cool, I just don't want to get too weak of a clutch!!
    Southside
    You'll be good with a comp stage 2.
    TheMyth
    I always mix matched my clutch setups. I used clutchnet 6 puck sprung hub and clutchmasters stage 4 pressure plate. The disk had the grip that i needed and the pressure plate had the foot pedal tension that was ok to even drive thru rush hour traffic. I used this same clutch setup in my dohc setups as well as my turbo'd sohc 400whp/318 torq on 93 oct.
Tags for this Thread
