Results 1 to 11 of 11
Thread: ls emissions :(
    rollin 91 da egpower904's Avatar
    Dallas, GA
    Default ls emissions :(
    Ok so my ls failed emissions. Only failed on no ppm, both tests. 1746 out of 1258 and 2008 out of 1378.
    Ls block
    Type r pistons
    Stage 2 cams
    Cam gears
    Exhaust.
    In an 88 crx si.
    I zeroed out the cam gears and timing on distributor is advanced, it won't really idle if its in the middle. Is there anyway I can manipulate the cams via cam gear timing to make it emission freindly?
    DA SQUAD MEMBER #70
    91 da/95 gsr/boosted/awaits tune....
    retard the ignition timing, it could be the cylinders are too hot.
    Dallas, GA
    When I put the distributor timing even to the middle it barely idles (350-500). I was wondering if I could do something with the cam timing to help it out.
    DA SQUAD MEMBER #70
    were the cams properly degree'd in?
    wait, do you have a catalytic converter on your car?
    McDonough
    You failed nox?
    Bitches love bacon.
    Dallas, GA
    Yeah nox, it has a cat, and idk about cam install, they were advanced on intake cam and retarded on exhaust cam, I set. The gears to 0 and now it won't idle unless distributor is fully advanced, I don't understand the cam timign thing. I guess I'm looking for a rough estimate of where to degree the cams so that I can retard the distributor and chug this bitch through emissions lol. Thanks in advance
    DA SQUAD MEMBER #70
    Dallas, GA
    Brand new egr valve too.
    DA SQUAD MEMBER #70
    McDonough
    Replace the cat.
    Bitches love bacon.
    LAWRENCEVILLE
    Quote Originally Posted by egpower904 View Post
    Since when does a ls motor have a egr valve
    Hella stock member!
    lol. retard the timing as much as you can, hope for the best.
