Thread: front lug nut stud and bearing replace
    lawrenceville,ga
    Default front lug nut stud and bearing replace
    i recently bought a 95 integra and i found one of the lug nut stud broken in the front passeger side. I heared fom some friends that is best to replace the wheel bearing at the same time.. i was wonding if i would get u guys help i just need like a pictures or video that shows step by step how to do it so i can do the work my self..
    thanks in advance
    barrow county
    wheel bearing dont just randomly go bad. you got to: ( there are tons of reason but most common )
    1: turn like a maniac at high speed
    2: lose axle nut (bolt)
    3: improperly tighten rims/wheels
    you will have to take the spindle pretty much off to change wheel bearing while wheel stud only need about 5 min to replace.
    The Slums of GA
    easy shit.
    Feb 2010
    Zebulon
    you can do this your self. it doesnt need to be pressed in, atleast in the sence that you seee. you can do ball joints as well. impact tools make it easier but not necessary.
    sounds like a loose wheel as far as the bearing AND stud.
    Apr 2009
    Villa Rica
    youtube
    lawrenceville,ga
    thanks for the help guys reppss
    the bearing has to be pressed. i just had one done saturday.
