Results 1 to 5 of 5
Thread: lsvtec swap
    Default lsvtec swap
    I have a ls block and a vtec head for a 1995 gsr, Ian putting in the crank and pistons from the b18c1 block into the b1 block. I did a little research and wastold that was the best thing to do for my v tech head, however, I notice that I do not have a oil cooler or cooling nozzles on my LS I have swap the oil pump and the water pump,thermo housing and plumbing. do you guys think it is going to overheat and is there anything you guys recommend I do to make these work. Thank you for any suggestions.
    del sol? 94_teg_ls's Avatar
    i shouldn't over heat unless you beating the hell out of it, but if you have a good radiator you should be fine.
    /sig
    It seems this is your first engine build, its best to leave it to a pro or a buddy that knows what their doing
    Southside Ridin HATCH
    x2
    Cobb County
    No, it should not overheat.
