Results 1 to 16 of 16
Thread: 2000 Accord F23A1 wont start
    stockbridge ga
    Exclamation 2000 Accord F23A1 wont start
    Thursday of last week the crank pulley fell off on I-75 and ever since the car will not start.
    We pulled the pulley, bolt, and the key from a yard the following day.
    New timing belt, water pump, plugs, and wires were changed since we were already under there.
    The timing in DEAD on.
    There is spark, its a light spark but its still getting a full arc on the plug.
    There is plenty of fuel.
    The cam gear is turning roughly 3/4-1 second for a full rotation with the key turned, is this normal?
    ANY HELP WOULD BE GREATLY APPRECIATED
    chuck-norris-a-souris
    LAWRENCEVILLE
    Did you check the compression?
    Hella stock member!
    stockbridge ga
    I'll be doing that as soon as Oreillys opens tomorrow morning.
    Is there any other possible issues?
    vtakkk hondaxpurt's Avatar
    TALKING ROCK, GA
    is the rpm gauge reading anything when you try to crank it? if not check the crank sensor and see if it broke. this is assuming the engine turns over when it "wont crank"
    98 Acura Integra LS-DD
    ??????????????????-project
    stockbridge ga
    completely to get the compression tested today
    but the rmp wasnt moving when we were trying to start the engine... a new one set us back 200$
    the timing light isnt flashing at all when we turn the motor over.
    :edit: and its still not moving...please dont say wiring
    AccuracyPerformanceAutomotive
    What??
    500whp of spinnin fury!!!
    del sol? 94_teg_ls's Avatar
    Quote Originally Posted by CaTcH22 View Post
    What??
    what he said from what i can get out of it check your dizzy
    /sig
    OOOOOH ok
    TALKING ROCK, GA
    my vote is still CKP (crank sensor). if you replaced your cluster (which is what i assume from what i gathered) this will not saolve the rpm problem but a crank sensor will.
    I bet I can fix it.
    SOUTHSIDE
    crank sensor must have broke or disconnected
    stockbridge ga
    Sorry about the poor grammar and total lack of complete sentences from before.
    So the CPS is new, the wires and plugs are new the dizzy is pretty much new, and the cluster is the original one.
    So with the f23a1 of you try to retard the timing with the 2 "female" electrical connecters on the coilit will advance it self and get you nowhere?...
    But it's pulling a misfire code for 2 and 4 and p1399(manufacture specific) it's hard to describe what is going on at the moment so I'm borrowing a video tonight and will post a video or2
    Last edited by gar9854; 12-28-2010 at 10:08 AM. Reason: Forgot a few words...again
    for a small fee since your close i'd gladly come by and get that thing running, if possible that is.
    you stole my words
    /sig
    TALKING ROCK, GA
    anyone figure this out?
    I bet I can fix it.
    I bet I can too...lol j/k
