Results 1 to 13 of 13
Thread: how to remove abs in a teg
    Sep 2010
    Default how to remove abs in a teg
    i have a teg and i want to take out the abs how can i do it
    Feb 2010
    Zebulon
    use braided steel to run a prop valve and connect to the appropriate lines on the ppassenger side of the car where your oem intake resides.
    McDonough
    Just curious as to why you would want to remove something like that...
    Bitches love bacon.
    cut it off, its not like you need your brakes anyways
    Oct 2003
    Why would you wanna take out the ABS? If the module isn't working, it just bypasses and works as a normal unit but if it's working, you have the benefit of having shorter braking distances, not to mention a more stable braking under cornering without having to worry about a wheel locking up. So again, why?
    okay okay, i was just kidding about cutting it. you will need ALL parts from a RS integra, what these dudes^ said is right, why remove it? but again its your car so imma tell you how. get all RS integra parts and lines, remove all your ABS parts, lines. Then install, done.
    Quote Originally Posted by xero_xero View Post
    do not do this. this is a failure within a failure
    __DailyGrind
    or pay me and you wont have a headache and abs!
    southside
    Quote Originally Posted by i4_garage View Post
    What he said lol!!!
    why delete something that can possibly save your life?
    Peek-a-boo mofucka what now?!
    R Town Rida claybird's Avatar
    Coosa...Kinda Outside Rome GA
    Start pulling on stuff under you hood and eventually u wll acheive ur goal!
    WANTED:
    A Girl That is DTF for a PhD
    Feb 2010
    Zebulon
    dont start tearing apart your car. the abs bypass os pretty strait forward. you have to add a prop valve, 2 lines from the prop valve to the 4 abs lines. ill post up pics in a while of how it should be done.
    Quote Originally Posted by DVSRX-7 View Post
    ive seen more accidents due to ABS lockup than accidents with no abs
    Feb 2010
    Zebulon
    Unsubscribed, due to flaming little girls. pm me if you need help or have questions about the whole process.
