Results 1 to 14 of 14
Thread: So SCs = tanks, ran over a curb, damage pics
    ZOMG ChnkyLao's Avatar
    Winder, GA
    Default So SCs = tanks, ran over a curb, damage pics
    Last night it was pouring raining, black ass roads, and I thought I had turned into the turning lane of an intersection, but it ended up being a U turn lane. I was slowing turning into the lane and I noticed there was a cement median. Unfortunately my first thought was there was there shouldn't be a median there, then i ran the median over with the drivers side of the car
    I knew my front tire was gone instantly the rears questionable. Everything else seemed bad at the time. I pulled over to the gas station next to the turning lane. Got out of my car and saw freakin oil leaking under. Turned the car off instantly. The leak stopped after I turned the car off.
    Left the car at the gas station allday and got towed it back with the F250 and my cousins car trailer
    Got home, lifted all four wheels on jackstands and discovered this
    The car survive it, no damage to the motor mounts, engine, transmission, transmission mounts, cv axles, radiator, front bumper nothing, I was amazed. The car still drives just leaks oil. The car has well over 300k on most of the parts in the car.
    The gasket to the oil pan collapsed under pressure and the upper oil pan cracked a lil. Other than the obvious rim damage that was it. This car is freakin sturdy as hell. Of course I haven't removed the oil pan yet to check the real damage, which ill do after finals.
    A chunk of metal was actually ripped from idk what that is really
    The ATB? oil pan gasket pretty much collapse or got squshed under the pressure
    The upper pan has a small hairline crack in it
    unfortunately my bent rims
    How my car sat before the accident
    Plans on fixng?
    *take the oil pan out, check it up and down
    *weld the upper pan if I can
    *change out the gasket
    *bolt the pan back on and hope is doesnt leak anywhere else.
    *change out my springs in my coilovers from supra tts, to hypercoils,
    *the car will be garaged and worked on for the winter, so lots of things if money allows
    *2uz bottom end maybe?
    I do need a diagram to the upper and lower oil pans on a 95 sc400
    Projects
    Just when i was about to start thinking Asians maybe can drive but damn man lol j/k
    Winder, GA
    actually this is the second time i've done this in the same car, along with the other stuff thats extremely questionable. The car has proven how sturdy it can be
    and I question the same thing all the time
    Certified Gearhead iamdallas's Avatar
    Aug 2010
    Sucks man. My car is stuck on the side of a hill right now. The roads are iced so we're going to get it first thing in the morn... I just hope no one plows into it coming down the hill before I get a chance to go retrieve my property.
    Good luck getting everything back together.
    Oakland Cali Street and SouthSyde of the A
    g/l on your plans
    Winder, GA
    Quote Originally Posted by iamdallas View Post
    that sucks, I was in a huge rush to get my car today before it got too cold or dangerous to retrieve her. The idea of the F250 and a big trailer and a 4000 pound car strapped to it scares me,
    shes safely in my garage now though
    GL getting your car,
    Quote Originally Posted by LaoboiLB View Post
    g/l on your plans
    thanks
    Has anyone tried wheel wizards? imma call them tomorrow and see if i can get the rims fixed
    Aug 2010
    Quote Originally Posted by ChnkyLao View Post
    Much appreciated.... My nerves are on end. It's only about a mile away from here but if it gets hit all I have in minimum coverage. It will be home in 6 hours with a little luck though.
    McDonough
    Those wheels may never balance right again Sucks it happened.
    Bitches love bacon.
    Winder, GA
    I was hoping that wont happened, hopefully wheel wizards can work some magic
    McDonough
    They are in business for that reason. Hope it works out for you.
    Bitches love bacon.
    its your sign to not put anything bigger than 18's on that car lol. glad your car survived it.
    CD5 Accord
    sandy springs
    I wonder if poor tires contributed to this accident?
    Dec 2009
    lawrenceville
    Hope u get ur car back on the streets soon!!
    Winder, GA
    just called they can fix them for $140 a wheel
    Quote Originally Posted by msanch24 View Post
    eh maybe I had two sets of 18s on the car before and these 19s fill the gap very nicely,
    Quote Originally Posted by Marta Mike View Post
    I didnt exactly try to brake, plus im running stretched 35s. unless I had my stock 16s the rim would of been bent reguardless
    Quote Originally Posted by CRXdelsol View Post
    the sc will be back, probably after winter I dont like driving this car in winter, no traction control + rwd + ice did not work well for me last year
