- WTF compression question
- Rep Power
- 18
i have an ls swap in an eg i put the motor in and it ran on three cyl. so i checked compression and low on #1 so i take my head to the machine shop put some valves in it and milled the head. i put the head back on and no start at all less compression then when i started on all 4 cyl now. would the adj on the valves be out now? i cant get a feeler gauge in between the rocker and the cam so any imput would be rad.
- Rep Power
- 0
if you can't get the feeler gauge in, your valve lash is way too tight, and that is probably the cause of your lower compression. adjust the valves.
however, was there a bent or bad valve in the head? you cold have bad rings causing the low compression... did you do a dry and a wet test before you condemned the head?
Used head gasket or new?
Also yes Adjust the valves correctly.. It DOES effect your Compression readings.
- You may not post replies
- You may not edit your posts
Forum Rules
