Results 1 to 11 of 11
Thread: I want to know the proper way to lower/slam a car to the ground.
    more wood than noahs arc sirkus's Avatar
    Cartersville, Ga
    Default I want to know the proper way to lower/slam a car to the ground.
    I recently attained a 93 Del Sol. It has been lowered.. I believe on cut springs. I jacked the car up and I can't find any brand names.. and they look aged like they're stock. With the stock shocks. It rides/steers like crap. Rides semi-fine on the interstate, you just have to take it easy over bridges as to not bottom the car out.
    The front lip sits 3"-3/4" off the ground. The header is 2"-11/16" off the ground. It's not easily daily drivable. So I'm now in the market to build the suspension back to spec.
    I've heard a lot of people say look into the Skunk shock/spring set, but I was wondering what else I need to make the car more stable. I wouldn't mind the car coming up about an inch to an inch and a half. I just want to know the Right parts I would need to make it more handling friendly. Every slammed civic/teg/honda I've ever driven rides like a go cart, but they all had cut springs and stock shocks.
    2014 | Hyundai Veloster | Turbo R-Spec
    May 2010
    South Side
    get adjustable coilovers. tht way u can set it where u want it and go from there
    Sep 2003
    GC/Koni combo
    /thread
    McDonough
    Quote Originally Posted by 5spdfrk View Post
    GC/Koni combo
    /thread
    I have heard this same thing. Where are they available at?
    Bitches love bacon.
    aye bro .:Stirfry:.'s Avatar
    if you want to do it right spend some money. no lowering springs, no ebay coilovers, no cut or heated springs on stock struts.
    Fully adj coilovers is the way to go
    theres plently of brands to choose from
    but bang for the buck GC coilovers with kyb AGXs, or konis, or tokico
    my old civic wiith fully adj omni powers on the rear, tokico blues with GC coilovers on the frt.
    with 16 slips and i can could of gone down 2 more inches if i wanted to.
    tuckin rim in the back. and about the same on the front
    ATL DAsquad Member #9
    ebay/
    Cartersville, Ga
    Quote Originally Posted by .:Stirfry:. View Post
    So to make the car 100% driveable at a lower stance then all I need are coilovers and shocks? Are there any more parts that will help with handling?
    Hatch and that back drop looks sweet btw..
    Sep 2003
    Coilovers and shocks are just the beginning. Think about a sway bar combo as well.
    Certified Gearhead Thegrizz's Avatar
    Feb 2010
    Georgia?.
    adjustable coilovers-dont go with ebay brand if your picky their typically bouncy.i have a del sol with some ebays and dont get me wrong it handles really well but they are bouncy. i also have a camber kit. a lot of the time you lower a sol youll get camber wear unless you do some adjusting. get a used camber kit i never really cared brand name on a camber kit you can tell the quality by looking at it just make sure its not cheap metal or bolts. used like $30-$50. and get a coilover set.they can run from $50 -thousands.get something a little higher quality on those or else you'll noticed why they were priced cheap.as long as its a semi-heard of name your fine.hope that helped man.
    Quote Originally Posted by sirkus View Post
    thx,
    and yes for a start. the only coilover sleeve type i trust are ground controls. bc you can get them at different spring rate or your choice.
    and the struts are a personal thing, youll just have to go through them to see which ones you like the best.
    a camber kit and a sway bar kit as well.
    and dnt forget about extended top hats that are out there to help with the life of your struts, and the rebound of them. you can find these on ebay, or GC
    http://ef-honda.com/ben/tophat.jpg
    http://dut619.com/ek/koni2.jpg
    GOON oneSLOWex's Avatar
    Chattanooga,TN
    Koni Yellow/Ground Control. Thats what im riding on right now and love it. I got a little stiffer spring rate so I wont say it rides like its stock...its a bit stiff...but the ride is very nice and fun to drive. The shocks have lifetime warranty and are also adjustable. Lookup THmotorsports on Hondatech...got mine from them for $799 shipped a few months ago.
