Results 1 to 15 of 15
Thread: Civic major BRAKE problem
    Sohc Me Beautiful geezy's Avatar
    With Your Mom
    Default Civic major BRAKE problem
    theres been a thread already posted but mines a different case..
    i recently changed the rear caliper on the sedan..
    i bled the system about 10times on that side. the pedal seemed too low..
    bled it 5more times, came up to normal height.
    but once the pedal is bein pressed for a long time it sinks down almost to the floor n i have to repump it...
    i bled the other rear break just incase .. and just now as i was drivin the pedal didnt come up. when it was suppost to n my brakes went out for a second, pedal came up n now its fine... what can be this problem?
    Projects
    Quote Originally Posted by geezy View Post
    sounds like a leak
    With Your Mom
    sounds like a leak
    how can i find this leak?
    Projects
    well im sure if its a leak you should see fluid around the calipers or lines somewhere. If not then your brake booster could have busted.
    No lines or bolts cross threaded and leaking air in ?
    Loves Twinkies Schroeder's Avatar
    Oct 2009
    In the Garage
    If your pedal is going to the floor its, air in the system, Leak, or Master cylinder. Seeing as it worked fine before your caliper change, I'd check for leaks at the brake caliper hose connection, and also bleed the shit out of it.
    The Shitbox
    With Your Mom
    illl lift the car up and double check right now
    Quote Originally Posted by Schroeder View Post
    ive bled the caliper i changed like almost 15-20times, tomorro will stop by a brake specialist and get a second opinion
    ^^this guy loves you jdm-civic's Avatar
    the sky
    brake booster
    Emancipate yourself from mental slavery, non but ourselves can free our minds- Bob Marley
    facebook me: http://www.facebook.com/profile.php?id=779918877
    With Your Mom
    is it hard to change
    Oct 2009
    In the Garage
    Since the MC Reservoir is the same for both front and back brakes, If the level of fluid dropped enough in the master cylinder reservoir while you were changing the rear brake caliper, it is possible that you may have sucked air into the front brake system. You need to bleed all of the brakes. Try that before taking it to someone else and spending cash.
    I doubt its your Booster as its a metal rod that goes from your pedal to the piston of your MC with a vaccum diaphragm (SP) in the middle. If i was broken the pedal should be loose as shit. Do you hear a vacuum leak coming from the booster? Seeing as you're talking about the pedal being low I'm assuming you don have heavy pedal effort. Therefore more than likely your booster is just fine.
    The Shitbox
    aye bro .:Stirfry:.'s Avatar
    i would change the MC. if it was the BB the pedal would be a bit hard. if it was leaking.
    ATL DAsquad Member #9
    With Your Mom
    Quote Originally Posted by .:Stirfry:. View Post
    Thanks guys ill be sure to bleed each wheel tomorrow to make sure, i appreciate the help! Repss
    also when bleedin start with the one furthest away frm the mc RR, LR, RF, LF
    i just had the same sinking problem on a 92 Accord wagon. The fix - brand new OEM master cylinder. No more pedal to the floor. Expensive but effective lol.
    Oct 2009
    In the Garage
    Did you figure out what it was?
    The Shitbox
    Feb 2010
    Zebulon
    x infinity on the master cylinder.
    if it were your brake booster, the pedal would be stiff and hard to push.
