Results 1 to 11 of 11
Thread: ls/v help!!
    Certified Gearhead JDMDA_1.7's Avatar
    that 90001!
    Default ls/v help!!
    so my buddy just had a ls/v done to his eg hatch..he used good quality parts and it was done professionally.so he gets it out the shop and a couple hours later it starts to smoke bad!!!.its white smoke.so we are thinking it might be the gas in the car because it was sitting for about a year before the swap was done,,weird thing is that it smokes a lot and then it stops smoking for like an hour lol..if ya had any ideas what it could be then i would really appreciate it if ya helped me out..thanks IA
    got vtec?
    ^^this guy loves you jdm-civic's Avatar
    the sky
    did you guys use a new head gasket?
    Emancipate yourself from mental slavery, non but ourselves can free our minds- Bob Marley
    facebook me: http://www.facebook.com/profile.php?id=779918877
    that 90001!
    yea man ..he got the golden eagle kit..that came with new head gasket
    got vtec?
    McDonough
    Can we assume brand new rings and all that jazz too? Checked the coolant level?
    Bitches love bacon.
    Smyrna
    Quote Originally Posted by JDMDA_1.7 View Post
    If it is white smoke, mostly leaking coolant is mixed in were is shouldn't be. Even though you used the GE LS/V conversion kit, you could have problems with either the head or the block being warped. Did you have either checked or did you rely on someone's word to there quality? Furthermore, if its smoking for a while and then stops, you probably burning up all your coolant in the combustion chamber.
    98 EJ8 - Stolen ( Thieves)
    Feb 2010
    Zebulon
    Agreed. white smoke signifies coolant being burned inside the engine. it should not mix. it may be any of the following or a combination of:
    Warped head
    Poor gasket installation
    incorrect torque specs or torque sequence
    old/poor fuel
    Check coolant levels and check for air. also check the oil for coolant. if oil is getting into the combustion chamber, it could be geting other places which could lead to bearing or ring failure.
    that 90001!
    thanks u guys for the help.and yes he had new rings..and the bottom end was checked before the build and so was the head ..they both came out good no problems.and we keep checking the coolant and its fine lol..my first thought was that it was poor fuel..am thinking shop put the head gasket wrong ,bc we had that problem from them before.
    got vtec?
    McDonough
    You had a problem with a shop installing something wrong and you still took something back to them?
    Bitches love bacon.
    that 90001!
    the car is not mine man..its a friends,,i told him not to take it but he did anyways.and this is what happened. i hate to say i told him so!
    got vtec?
    McDonough
    Let him learn the hard way.
    Bitches love bacon.
    that 90001!
    that's what am saying lol
    got vtec?
