Thread: gsr block, ls rods, ls crank, usdm type r pistons. p73 ao
    Default gsr block, ls rods, ls crank, usdm type r pistons. p73 ao
    i already got a compression calculator. it's about 11 something compression. my question is,what cams can i get away with using?
    b18c1 block with factory head.
    2002 gsxr 600 fun weekend toy
    91 mustang gt, daily driver
    95 civic coupe. bolt ons. best of 9.2 with 2.35 60 foot.
    no traction on nitrous, ran slower than motor up to this point.
    Whatever you want really. LOL. Also get rid of the oil squirters. They are gonna hit the pistons and the counter weights on the crank. Golden eagle makes the oil squirter plugs.
    My line of work
    www.internationaljets.com
    theres no need to delete the squirters. i left them in there. i rotated the cylinder, there was plenty of clearence and i've put 1000 miles on the motor. just fried a valve from nitrous though so i'm doing a little work to the head. just wanted to know what i could get away with.
    McDonough
    Use whatever cams you want. Get some upgraded springs to go along with them and get a tune.
    Bitches love bacon.
    I'm not sure if you knew at the time but I'll be a whole lot of money that they are hitting, or used to be before they got beat. Or they are constantly robbing power. Its not just me, look it up they need to be modified to clear. They hit the lower side of the piston and counter weight on the crank. And there is only plenty of clearance on 2 cylinders...
    My line of work
    i checked the cylinder , turned the motor over several times to see if they would hit. i did bend them a tiny bit, but after they were bent there was about a centimeter of clearence on all cylinders between counter weights and squirters as well as piston and squirters. i turned the motor over several times to see if either would hit and neither did. i'm about to pull the bottom end back apart and i'll check them again, all i did was bend them down a hair.
    Feb 2010
    Zebulon
    your engine is going to tare through some rings. you should never turn the engine over more than once while assembling. it tears away your assembly lube.
    R A W! x Resilience's Avatar
    Atl
    Why LS rods?
    You niggas know my pyroclastic flow, its R A W!
    - Current: E36
    Quote Originally Posted by x Resilience View Post
    Why LS rods?
    A little added displacement
    My line of work
