Thread: F22B and H23A1
    Exclamation F22B and H23A1
    Whats the difference between the two except for displacement, and would the turbo F22B be as good as turbo H23A1. I was gonna drop a H23A1 into my 97 Accord and turbo it but cant find a decent engine but anyways I'm still lookin' in case anybody got one so can somebody answer my question please thanks
    DC5-R
    Gwinett
    Not sure if this will help, don't know too much about H and F series but the H23a1 is a lil bigger I believe in displacement 2.3L and the F22 is 2.2. Both have low compression already too...sorry if that didn't help.
    Duluth, G-nett
    H23's are non vtec engines. you would gain more torque if you boosted that engine. F22 are single cam. I would boost the f22, and also has good torque numbers. now, if money isnt an issue, h23 for the monster torque.
    DC5-R
    Gwinett
    Quote Originally Posted by 95boostedteg
    lol dude, F22B is DOHC non-vtec also man
    Duluth, G-nett
    Quote Originally Posted by krucial7integra
    lol. you're right. was thinking of the f22A.
    The ShotkallA Complete's Avatar
    there aint much different... i got a h23 accord... i took out the f22... i have the headers from my f22 on the h23 and and also the intake .. h23 has more hp and more torque... this probably dont even help you out.. lol
    Complete
    To 942JZGTE 93H22ACX's Avatar
    F22 has less hp and torque to start off with... the crank and rods are the same... so internally the H23 and F22 are the same...
    H23 has larger displacement, more torque, more hp. if you can get either one for the same price.. get the H23. but if the F22 is cheaper go with that.
    i would go with the H23 and put a H22 head on it... its easier than putting a H22 head on the F22 block
    the F22 also has iron sleeves which makes it easier to install forged pistons without resleeving like the H22 and H23
    here's some information i found
    Deck Height
    H22A4 Block = 8.643
    H22A block = 8.643
    H23A block = 8.643
    H23A1 block = 8.643
    F22 block = 8.643
    F23 block = 8.643
    F20B block = 8.643
    Bore
    H22A4 Block = 87mm/3.425
    H22A block = 87mm/3.425
    H23A block = 87mm/3.425
    H23A1 block = 87mm/3.425
    F22 block = 85mm/3.346
    F23 block = 86mm/3.385
    F20B = 85mm/3.346
    Note:
    Due to various available piston diameters (A/B) actual bore diameter may vary
    Rods
    Length
    H22A4 = 5.633
    H22A = 5.633
    H23A = 5.572
    H23A1 = 5.572
    F22 = 5.572
    F23 = 5.551
    F20B = 5.709
    Width
    H22A4 = .935
    H22A = .935
    H23A = .935
    H23A1 = .935
    F22 = .935
    F23 = .780
    F20B = .935
    BE Bore
    H22A4 = 2.008
    H22A = 2.008
    H23A = 2.008
    H23A1 = 2.008
    F22 = 2.008
    F23 = 1.890
    F20B = 1.890
    Pin Bore
    H22A4 =
    H22A = .8649-.8654
    H23A =
    H23A1 = .8649-.8654
    F22 = .8649-.8654
    F23 = .8649-.8654
    F20B =
    Pistons
    Bore
    H22A4 = 87mm/3.425
    H22A = 87mm/3.425
    H23A = 87mm/3.425
    H23A1 = 87mm/3.425
    F22 = 85mm/3.346
    F23 = 86mm/3.385
    F20B = 85mm/3.346
    Note:
    actual diameter may vary depending on code of piston (ie, A B)
    Compression Height
    H22A4 = 1.221
    H22A = 1.221
    H23A = 1.203
    H23A1 = 1.203
    F22A1 = 1.203
    F22A4 = 1.203
    F23A1 = 1.181
    F20B = 1.221
    Dome Volume
    H22A4 =
    H22A =
    H23A =
    H23A1 =
    F22A1 =
    F22A4 =
    F23A1 =
    F23A4 =
    F23A5 = -18cc
    F20B =
    Wrist Pin Diameter
    H22A4 = .866
    H22A = .866
    H23A = .866
    H23A1 = .866
    F22 = .866
    F23 = .866
    F20B = .866
    Crankshafts
    Stroke
    H22A4 = 90.7mm/3.570
    H22A = 90.7mm/3.570
    H23A = 95mm/3.740
    H23A1 = 95mm/3.740
    F22 = 95mm/3.740
    F23 = 97mm/3.818
    F20B = 88mm/3.464
    Main Journal Diameter
    H22A4 = 55mm
    H22A4 = 50mm (1997 Only)
    H22A = 50mm
    H23A = 55mm
    H23A1 = 50mm
    F22 = 50mm
    F23 = 55mm
    F20B = 55mm
    Rod Journal Diameter
    H22A4 = 1.888
    H22A = 1.888
    H23A = 1.888
    H23A1 = 1.888
    F22 = 1.888
    F23 = 1.771
    F20B = 1.771
    Cylinder Heads
    Combustion Chamber Volume
    H22A4 = 53.8cc
    H22A = 53.8cc
    H23A = 53.8cc
    H23A1 = 50cc
    F22A1 = 50cc
    F22A4 = 50cc
    F23A1 = 50cc
    F23A4 = 50cc
    F23A5 = 50cc
    F20B =
    Intake Valve Diameter
    H22A4 = 35mm
    H22A = 35mm
    H23A = 35mm
    H23A1 = 34mm
    F22 = 34mm
    F23 = 34mm
    F20B = 34mm
    Exhaust Valve Diameter
    H22A4 = 30mm
    H22A = 30mm
    H23A = 30mm
    H23A1 = 29mm
    F22 = 29mm
    F23 = 29mm
    F20B = 29mm
    Head Gaskets
    Bore
    H22A4 = 88mm
    H22A = 88mm
    H23A = 88mm
    H23A1 = 88mm
    F22 = 86mm
    F23 = 87mm
    F20B = 86mm
    Thickness
    H22A4 = .026
    H22A = .026
    H23A = .026
    H23A1 = .026
    F22 = .026
    F23 = .026
    F20B = .026
    Note:
    Gasket thickness measured after crush
    94 Supra= 500rwhp
    Quote Originally Posted by 93H22ACX
    Deck Height
    H22A4 Block = 8.643
    H22A block = 8.643
    H23A block = 8.643
    H23A1 block = 8.643
    F22 block = 8.643
    F23 block = 8.643
    F20B block = 8.643
    Bore
    F20B = 85mm/3.346
    Note:
    Rods
    Length
    H22A4 = 5.633
    H22A = 5.633
    H23A = 5.572
    H23A1 = 5.572
    F22 = 5.572
    F23 = 5.551
    F20B = 5.709
    Width
    H22A4 = .935
    H22A = .935
    H23A = .935
    H23A1 = .935
    F22 = .935
    F23 = .780
    F20B = .935
    BE Bore
    H22A4 = 2.008
    H22A = 2.008
    H23A = 2.008
    H23A1 = 2.008
    F22 = 2.008
    F23 = 1.890
    F20B = 1.890
    Pin Bore
    H22A4 =
    H22A = .8649-.8654
    H23A =
    H23A1 = .8649-.8654
    F22 = .8649-.8654
    F23 = .8649-.8654
    F20B =
    Pistons
    Bore
    H22A4 = 87mm/3.425
    H22A = 87mm/3.425
    H23A = 87mm/3.425
    H23A1 = 87mm/3.425
    F22 = 85mm/3.346
    F23 = 86mm/3.385
    F20B = 85mm/3.346
    Note:
    Compression Height
    H22A4 = 1.221
    H22A = 1.221
    H23A = 1.203
    H23A1 = 1.203
    F22A1 = 1.203
    F22A4 = 1.203
    F23A1 = 1.181
    F20B = 1.221
    Dome Volume
    H22A4 =
    H22A =
    H23A =
    H23A1 =
    F22A1 =
    F22A4 =
    F23A1 =
    F23A4 =
    F23A5 = -18cc
    F20B =
    Wrist Pin Diameter
    H22A4 = .866
    H22A = .866
    H23A = .866
    H23A1 = .866
    F22 = .866
    F23 = .866
    F20B = .866
    Crankshafts
    Stroke
    H22A = 90.7mm/3.570
    H23A = 95mm/3.740
    H23A1 = 95mm/3.740
    F22 = 95mm/3.740
    F23 = 97mm/3.818
    F20B = 88mm/3.464
    H22A4 = 55mm
    H22A = 50mm
    H23A = 55mm
    H23A1 = 50mm
    F22 = 50mm
    F23 = 55mm
    F20B = 55mm
    H22A4 = 1.888
    H22A = 1.888
    H23A = 1.888
    H23A1 = 1.888
    F22 = 1.888
    F23 = 1.771
    F20B = 1.771
    Cylinder Heads
    H22A4 = 53.8cc
    H22A = 53.8cc
    H23A = 53.8cc
    H23A1 = 50cc
    F22A1 = 50cc
    F22A4 = 50cc
    F23A1 = 50cc
    F23A4 = 50cc
    F23A5 = 50cc
    F20B =
    H22A4 = 35mm
    H22A = 35mm
    H23A = 35mm
    H23A1 = 34mm
    F22 = 34mm
    F23 = 34mm
    F20B = 34mm
    H22A4 = 30mm
    H22A = 30mm
    H23A = 30mm
    H23A1 = 29mm
    F22 = 29mm
    F23 = 29mm
    F20B = 29mm
    Head Gaskets
    Bore
    H22A4 = 88mm
    H22A = 88mm
    H23A = 88mm
    H23A1 = 88mm
    F22 = 86mm
    F23 = 87mm
    F20B = 86mm
    Thickness
    H22A4 = .026
    H22A = .026
    H23A = .026
    H23A1 = .026
    F22 = .026
    F23 = .026
    F20B = .026
    Note:
    Now this answer does more than help thanks alot
