Results 1 to 15 of 15
Thread: Need help, car running rich and hesitating
    L'ville / Gwinnett
    Default Need help, car running rich and hesitating
    Ok guys, heres the deal.
    I have an eg with a SOHC swap. Its been running a little rich but today its starting stuttering and missing at idle and low rpm.
    I picked up a set of 180 injectors and a new set of plugs (it still has the p05 ecu so I'm thinking its pulsing the 230s on the motor too long and loading it up with fuel) that I was going to swap in tomorrow.
    I may have a fouled plug, but what else do I need to look into. I've gotta get this thing running right by tomorrow night.
    Thanx in advance.
    Titties!!!
    first off i would run the right injectors and ecu for the swap you have or a similar one, you may also be using the wrong FPR, or if you have an adjustable one it could be set too high. i get fuel burn on my si running the right ecu and having it at the very bottom of the minimum FP for my si and i still have black fuel burn smoke/soot on the back of the car. what motor do you have exactly?
    L'ville / Gwinnett
    SOHC ZC (D16A6)
    L'ville / Gwinnett
    OK guys, today I replaced the cap, rotor, plugs, and installed a set of 180 injectors with new o-rings.
    The car ran great for 20 minutes and while I was cleaning up my tools it once again developed a miss and completely died. Now it just misses and bucks.
    Its obviously thermal so what should I look for? Ignition module? Coil? One thing I did notice that may or may not be related is that there was some sort of goo inside my old dizzy cap...
    I need help guys, this car has to get me to work on monday!
    McDonough
    Is this a new swap?
    Bitches love bacon.
    WEST_SIDE
    if u have acces to a scanner, try and see what he freeze data shows.
    L'ville / Gwinnett
    Nope, no scanner... Gotta go shadetree on this one. The ZC swap isn't new, its just not common because its not much of a performer. All suggestions still welcomed. Is there anyway to test the dizzy. I know thermal failure is common on older GM style HEI distributors but I just don't have the $ to keep guessing.
    your right hand man 97_luder's Avatar
    I had the same problem with my car and the problem was the throttle body. The throttle stop screw was set to low and the butterfly would get stuck closed. This made my car run rich and idle like s*^t. got new plugs and raised the throttle stop screw and my problem went away. i hope this can help you out.
    G/L
    L'ville / Gwinnett
    Sunday morning bump.
    WEST_SIDE
    it might be that p05 ecu liek someone mentioned above. i'm not 100% sure but u might want to pm a tuner be be exact.
    L'ville / Gwinnett
    Unless the ECU went bad, I doubt it only because the car has been running fine for three months.
    WEST_SIDE
    ahhh so it ran good witht he same swap. I'll try and find my chart on checking the ignitor and module to post it up. i know I have it on PDF somewhere
    L'ville / Gwinnett
    Thanx
    Titties!!!
    i may have an ignitor somewhere that is a spare for you to try to see if that's the problem. any other sensor in the dizzy will throw a CEL but the ignitor wont.
    L'ville / Gwinnett
    Dizzy ftmfw! Thanx guys.
