Results 1 to 24 of 24
Thread: overheating
    Default overheating
    ok, so my cousin's 1995 integra is overheating. We know it's not the headgasket and waterpump. the reason how we know is because it's not smoking, and plus, we had jus recently replaced them 2 or 3 months ago. Well, after driving for a while, the water in the radiator will transfer into the white bucket beside the radiator. when the white bucket is filled up with antifreeze, it'll than start to overflow. so the radiator than, won't have any water left. I'm thinking it's the radiator cap? oh yeah, we had replaced the thermostat last month, when it overheated, he decided to just take it off and ride with no thermostat. Any ideas? Repps will be given.
    Senior Member Patterson's Avatar
    Summerville
    sounds like your getting pressure in the cooling system. i only know one reson for that and its a blown head gasket. well it could be a crack in sleeve or head but pretty sure its comming from the combustion chamber.
    can't it be because the radiator cap is bad? or if the radiator is clogged up??
    Summerville
    it could be. but everytime i've ran into this issue it led to the head gasket. with a pressure tester you can narrow it down to see if it is the cap.
    any more suggestions?
    after driving are both of the rad hoses hot ( upper and lower )?
    iono, didnt really pay attention to it. but i think it was cold.
    barrow county
    Quote Originally Posted by Patterson View Post
    blown head gasket will able water to enter the cylinder causing the exhaust to blow out white smoke. the teg isnt blowing out white smoke
    barrow county
    Quote Originally Posted by hmong_Spec View Post
    forgot to check the bottom hose but the top was cool
    did you put just water in it? or did you use a mixmix of antifreeze and water? straight water will boil before the engines gets to it running temp
    it had antifreeze in there, than it kept on overheating, so it ran out of antifreeze and than he putted water in there.
    in the OP i read that your car doesn't have a thermostat. if you are dead certain it isn't your headgasket then you should buy a new thermostat, install it and fill with mixmix antifreezewater
    actually, he just went and bought a new thermostat last month. It overheated with the new thermostat in there. so he decided to than take it off, and run with no thermostat and see how it goes. But it than yet overheated
    Quote Originally Posted by Purple Power View Post
    try a new cap then, with new fluid.
    but will a bad radiator cap cause it to be like this?
    Summerville
    Quote Originally Posted by blue_gt View Post
    i read the OP i have seen it before and the car never white smoke that you can see.
    Is not a male
    South southside.
    x2
    My car never smoked when I blew the head gasket. Could have overheated due to the thermostat put in a month ago and now has another blown head gasket. Also, have you tried bleeding the cooling system?
    Test your radiator cap. Have seen it happen a bunch.
    Also in some instances no thermostat will cause overheating as well.
    ^^^ back than, he ran with no thermostat and it was fine. but he'll test out the cap.
    Stang Mod slostang's Avatar
    Southside
    advance carrys a kit to test your cap. they will test it for you right in the store if they guy knows wtf hes doing.
    L'ville / Gwinnett
    If the head has raised just slightly it will cause your symptoms but not let coolant into the combustion chamber... I had this happen once on a Mustang. Look at your hoses and see if the upper one has stretched or swollen around the clamps... Also, start the car and see if the upper hose swells up immediately.
    co signing
    thanks for the help guys, i'll tell my cousin about all these advices.
    barrow county
    Quote Originally Posted by slostang View Post
    they probably wont, they couldnt figure out what was a rear main seal
