Results 1 to 36 of 36
Thread: Spin No Start
    IS300 NEMO's Avatar
    We Fuckin...
    Default Spin No Start
    1995 Acura Integra 5 speed p75 ecu
    will we are stumped at this point. car has compression, fire, and fuel.
    when the problem started:
    distributor locked up. replaced the distributor with new coil, button, icm, and cap. spins no start
    fuel pump is kicking on. plugs are firing(blue spark)
    took another running 1995 Acura Integra 5 speed and swapped the distributor, plugs, plug wires, and ecu same problem.
    checked the harness everything is plugged up.
    we need help at this point.
    known as Charles
    Did you do a compression test and if so what were the numbers. Have you checked the timing belt to make sure cams and crank are in time? Sounds like you have all three (compression, fuel, spark) just not at the right time. Also, have you checked for injector pulse?
    Main Stream Performance
    www.mainstreamperformance.com
    MSSracing.com
    IS300 NEMO's Avatar
    We Fuckin...
    Quote Originally Posted by Main Stream View Post
    haven't done a compression test. the timing looks like it might be off a tooth or 2 but the shouldn't cause it not to start right?
    going the get the noid tester from the shop tonight and check the injector pulse. that is our next step
    YOURMOM tnomud's Avatar
    Coweta
    Quote Originally Posted by NEMO View Post
    NOOO!!! a tooth or two off can keep it from starting, especially if the distributor is not 100% on the money. Go check that part. 95% of my failed "first starts" are usually timing related.
    dude im having this same problem with my 95 integra.
    IS300 NEMO's Avatar
    We Fuckin...
    Quote Originally Posted by blown_ss View Post
    have you tried the coil? i know honda was having a problem with the coils going bad so thats what we thought it was at first.
    what he said. check timing.
    With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion. - Steven Weinberg
    Coweta
    FWIW: those internal coils suck> I think most Advance Auto stores carry the dist. cap with the 5th terminal to convert it to a standard Accel or MSD unit used on about everything.
    i concur
    IS300 NEMO's Avatar
    We Fuckin...
    i concur
    so our next step is to fix the timing and checked the injector pulse.
    just got a brand new coil from oreilys (sp). all i get are pops from the exhaust like its wanting to start but it wont. im getting gas and spark but no start. when you figure yours out let me know.
    WEST_SIDE
    Check yoru firing order. sometimes the simplist things we over look.
    IS300 NEMO's Avatar
    We Fuckin...
    Quote Originally Posted by tnomud View Post
    we left the distributor loose and rotated it back and forth and still nothing. i've had a engine that was off a tooth before and it still started just didnt run right.
    we are not ever getting any popping. just turning over. doesnt even sound like its trying to fire. no backfiring or smoke
    IS300 NEMO's Avatar
    We Fuckin...
    Quote Originally Posted by SLow_POke View Post
    yeah i was going to say this also for blown ss to check. that was one of the first thing we checked on ours
    i have the right firing order, i've looked it up many times to make sure.
    yeah i wasnt getting the pops and then i bought a new coil and started getting them. it seems like there is something so small that is holding me back.
    WEST_SIDE
    If your getting "pops" from the exhaust, its miss firing or firing at the wrong order.. well If i understand it right.
    other then that. It happen to a buddy of mine. trying to set the firing order from a SOHC to a B16. had him baffleld for about 2 hours.
    I guess if all else fails OP, Try a buddies set of wires. you might be getting a spark but not strong enough.
    i followed the book that i have for the car and googled it. i thought that could be it but i have looked it up.
    IS300 NEMO's Avatar
    We Fuckin...
    yeah already tried this also
    Coweta
    it sounds silly, but did you check the wiring at the internal coil and that dumb little plug on the dizzy?
    WEST_SIDE
    well DAmn. lol.....
    those are the things i would check .
    Ignition
    Compression
    Fuel.
    If its all there then in your case the Timing and firing order.
    Im all out of Ideas. :P/ GL if u ever fix it keep us posted.
    explain
    Coweta
    explain
    -there the wires pass though the housing, can get pinched.
    -Where this harness grounds/mounts the coil
    http://home.comcast.net/~jrutski/dist/assy.jpg
    http://img524.imageshack.us/img524/1554/dizzy.jpg
    Where Am I
    Nemo after trying to start it for awhile which I bet you have been doing, are your plugs just full of gas? I'd check them to make sure all you injectors are working..... Have you seen this motor run yet, like in a previous car or something????
    oh i got it. just wasnt sure what you meant.
    Coweta
    I am at work............I take shortcuts and use poor verbage to save time
    IS300 NEMO's Avatar
    We Fuckin...
    Quote Originally Posted by Turbodude06 View Post
    yes plugs are wet. yes car has ran before
    Where Am I
    ok, then if you got air, fuel, and spark, then it must be timing or possible the ecu....
    IS300 NEMO's Avatar
    We Fuckin...
    swap an ecu from a running Integra. so it looks like its coming down to timing
    Where Am I
    Yea so that should be it, if not GOOD LUCK!!!
    you got this figured out yet?
    IS300 NEMO's Avatar
    We Fuckin...
    no wont be able to look at it until tonight
    lol yeah me either just wondering if you did.
    Coweta
    it's funny, I think some fail to realize that most peeps here have like............jobs and stuff....
    IS300 NEMO's Avatar
    We Fuckin...
    well my buddy started checking it out tonight. just the injectors with a noid tester and they was good.
    set it to TDC and found the the intake cam was off 2 to 3 teeth. reset the timing and it fired right up.
    thanks for all the help
    WEST_SIDE
    bingo
