Results 1 to 17 of 17
Thread: new ECU redline???
    Certified Gearhead cole98si's Avatar
    Henry Co
    Default new ECU redline???
    just installed another p2t in my civic
    but now it red lines at 3500 rpm?
    anyone know why?
    Norcross
    CEL on?
    Henry Co
    Quote Originally Posted by j0nbunklah0m View Post
    CEL on?
    yes but it always is due to straight pipe
    Aug. G.A.
    CAM SENSOR. crank sensor (if obd2) or bad ecu
    Yes I own a Y49 CRX. NO ITS NOT CURSED!!!!
    Henry Co
    Quote Originally Posted by squirrel View Post
    it didnt do it before the car was stolen and i put in the new ecu
    bad ecu or could the theives have fucked something up?
    and it has wayyyy less power in the lower rpms
    Aug. G.A.
    Quote Originally Posted by cole98si View Post
    the only other thing i could think of would be your MAP sen. make sure they anit cut any wires or unplugged sen.
    Henry Co
    man the fucked so much shit up i have no clue what they may have done.
    but i will check
    thanks,
    anyone else have any input?
    earth ????
    reflash it to a base map
    Henry Co
    Quote Originally Posted by jdm eg99 View Post
    sorry guys im learning.
    what does that mean and how do i do this
    Henry Co
    figured it out.
    i had a p2t obd2a but i bought a p2t obd2b
    the obd2a is jdm
    i used a jumper harness to link up the obd2b
    BUT unlike the obd2a the obd2b needs a crankshaft fluxuation sensor.
    which i do not have.
    have to get another p2t OBD-2a
    Oct 2008
    nice find. you could also tie the pinout of the cfs to ground because the purpose of that sensor is to detect movement; therefore when the car engine is running, it is grounded....i am not quite sure how this will effect the redline, but if you try it and it works, then let me know....it is safe to ground the I/O pin ...just make sure it is the right pin ....if you want to be safe then go to radioshack and grab a 10k resistor and a 100 ohm resistor and tie them in parallel between the pin and ground.
    figured it out.
    the obd2a is jdm
    there is a trick you can do to that ecu so that you dont need a fluxuation sensor. look it up. im sure its really easy to do.
    Oct 2008
    i believe the trick that he is refering to is tying the cyp and ckf together...this does not fix the problem, it just ties it to another sensor and piggybacks off of the data. it should work just fine, but you will also need to ground the ckf sensor pin to prevent the ecu from trying to read the non existing sensor in the first place. i forgot what pins correspond to what but i know all the pins that you need is on the big blue plug labeled "c". there should be 2 pins for the cyp, 2 pins for the ckf, 1 pin for the ckf out and of course 1 for the ecu gnd. sorry if the info is uber vague...i ll check the pinout info later at work and will update this afternoon if i can
    Quote Originally Posted by blown_ss View Post
    Oct 2008
    Henry Co
    Quote Originally Posted by k3tsurui View Post
    good find man! i will try it and let you know if it works
    Henry Co
    dude you are a LIFE SAVER!
    i tried it and it works perfectly!
    so instead of buying a new ecu
    i bought some 3 dollar quick splicers.
    thanks man!
    thanks man!
    hey hey where are my props? im the one that told you about it! lol. jk. glad you got it running right.
