Results 1 to 18 of 18
Thread: BMW question
    Banned STRteg's Avatar
    Oct 2008
    Somewhere in the USA
    Default BMW question
    Ok my boss has a1998 548i? (i think...) BMW and his upper radiator hose keeps popping off while hes driving as soon as the car gets warmed up which he says is after about 10 mins at the most. he says the temp gauge runs hot then the hose pops off and throws his coolant everywhere,what would cause this?says he has no heat eithe but hard to tell if the car was only running for 10 mins everytime befoe this happened not enough time for heat IMO
    423 KING
    Chattanooga, TN
    apparently thats a really common problem with those, has it had a radiator flush?
    18x9 +24 18x10+22
    Oct 2008
    Quote Originally Posted by lanning View Post
    no it has not could it be a bad thermostat?
    423 KING
    Chattanooga, TN
    Quote Originally Posted by STRteg View Post
    maybe, check and see if the fan is coming on and if there is air in the hose
    edit: could be temp sensor too
    18x9 +24 18x10+22
    423 KING
    Chattanooga, TN
    has he noticed it taking longer to get warm up in temperature? like the temp guage taking longer to warm up than normal?
    18x9 +24 18x10+22
    Oct 2008
    For this I'm not sure the radiator fan is not electrical but mechanical it moves with the motor
    Member
    Carrollton
    It's either a 528i or or 540i.
    Check his radiator endtank inlet. Those are plastic and tend to crack over time.
    98 Subaru Legacy GT
    89 325i. 400hp hoon-mobile.
    Oct 2008
    Quote Originally Posted by Logan View Post
    yeah 528i i believe and the upper radiator hose is disconnecting from the motor
    Member
    Carrollton
    He doesn't have heat because his coolant system needs to be bled.
    98 Subaru Legacy GT
    Member
    Carrollton
    Check his thermostat housing. Some of the thermostat housings are plastic. If it's plastic, it's probably broken. If it's aluminum, his radiator hose probably has a split in it.
    98 Subaru Legacy GT
    Oct 2008
    and this would cause the engine to run hot and his radiator hose to pop off?
    Member
    Carrollton
    I imagine his engine is running hot because his radiator hose is popping off.
    98 Subaru Legacy GT
    Oct 2008
    perhaps,but it might be running hot and then the coolant is getting too hot causing too much pressure in the hose and blowing it off? idk thats why im seeking guidance
    Oct 2008
    anybody?
    IA Member rexguy478's Avatar
    macon ga
    I'd say bad thermostat and its building up to much pressure. I think the thermostat and housing are built all together if i'm not mistaking and are purchased as one piece (I know a lot of bmw's are like that anyways) and most of the time advance auto parts can have it next day if ordered early enough. Just talk to someone who know what they are talking about. That's where I would personally start anyways.
    Oct 2008
    Quote Originally Posted by rexguy478 View Post
    Thanks for the input man,anyone else?
    Jan 2010
    honda land biatch
    radiator neck bout to break either thermostat stuck or pump going very common for that problem had it before on a 740
    Oct 2008
    Quote Originally Posted by sleeper1979 View Post
    Thanks for your input
