Results 1 to 14 of 14
Thread: Anyone know about Two-stroke engines?
    Ga
    Default Anyone know about Two-stroke engines?
    I was trying to start my 2stroke pocket bike and the pull cord was completely stuck and few days before i ran straight gas in it. do i need need a rebuild? how would i go about solving this?
    Ga
    anyone?
    YOURMOM tnomud's Avatar
    Coweta
    is the motor turning?
    Pull the plug and put a squirt of oil down in the cylinder. Put the plug back in, and try to push start it. I can't speak for you scooters motor, but I did about 50 laps at Tally (at 110MPH on a 100 degree day) on my KTM 2 stroke before I realized I didn't add oil to the tank on the way out.
    Ga
    ill try and get back to you
    not old....classic!
    Jan 2010
    Lawrenceville, GA
    sounds like an oil/fuel ratio screw up somewhere... might need to tear it down and look at the pistons just to check...
    Ga
    yeah i was running 100% GAS not even a ratio of oil so i guess thats why its stuck but ill try to squirt oil and if that does nothing i guess ill have to take it apart and see the internals thanks for the advice
    Yeahhhhh....may want to start running a mix...lol.
    Stang Mod slostang's Avatar
    Southside
    sounds like its locked up. lulz
    not old....classic!
    Jan 2010
    Lawrenceville, GA
    oh yeah!!!! imagine running your engine without oil..... whatcha think is gunna happen?
    Ga
    You save oil? haha but yeah i need a rebuild fosho its seized
    straight gas in a two stroke not good, will lock up piston
    and shred the crank, and rod bearing crank end
    Ga
    Anybody knoe where i can get some info on rebuilding little 2 stroke engines?
    SwiperNoSwiping!!
    Quote Originally Posted by chipper3663 View Post
    Its kinda easy... new ring, hone cylinder, usual engine rebuild stuff.
    I used to play with building/rebuilding these little motors back before i got into cars. Built a 36cc scooter and had it walking circles around a 50cc pocketbike that some kid had who lived up the street from me.
    If you want some more info...i would check out Gopednation.com, its kinda like the H-T for small 2stroke/4stroke engines/pocketbikes/scooters n' whatnot.
    u remind me of a wigger !
