Results 1 to 21 of 21
Thread: ◄Need a tool.....!►
    JDM TYTE AnthonyF's Avatar
    Default ◄Need a tool.....!►
    Does anyone have a 21mm Allen? I have a 19 but it's not big enough. it's for my R6 swing arm axle pivot bearing. It's holding me back from droping the bike and removing the engine.
    -Ant.
    The Carbon Fibered R6
    Southside Ridin HATCH
    ^ i see what your saying..
    There no way a socket will work?
    Senior Member Patterson's Avatar
    Summerville
    Quote Originally Posted by AnthonyF View Post
    -Ant.
    you can use a bolt head. put two nuts on the bolt and lock them together then use a socket or wrench to back it out. hope this helps
    Quote Originally Posted by Patterson View Post
    Fucking awesome. I dont think I have one that size but I will try it out. I found the tool I need on snap-on.com and the Yamaha dealers are closed. Fucking pussies.
    +41 for homey.
    -Ant.
    Summerville
    +41 for homey.
    -Ant.
    ace hardware is where i get mine. i also weld the two nuts together just to make sure they will not back off.
    ^I just went to my bike. My axle bolt fits kinda loosely. I dont have two nuts to use on it. Going to ace right now. Thanks again for the input!
    I don't have a welder at my garage, at my shop I do but I'm not there.
    -Ant.
    FUK IT! bowdown201's Avatar
    Next Door
    You need a tool? Look in the mirror
    Bingo! There's always more than one way to do something. Any hardware or any parts store will have a bolt with a head size of 21mm to 13/16".
    BOOM. Got that ish done. Now I just need to put the bike on the ground with the help of another person and figure out my color combo.
    -Ant.
    Summerville
    -Ant.
    are you droping the motor or removing the swing arm? i just use a jack and ease the motor down then wrestle/man handle it out. but i keep the front in a stand.
    Summerville
    btw i'll rep back when i get to a computer that will let me lol
    I just removed the swing arm and front section. All thats left is the engine and frame. I don't have a jack at my garage. I figured it'd be easier to unbolt it with the engine on the ground then lift the frame.
    I am powder coating the frame.
    -Ant.
    Summerville
    gotcha. i guess no cherry picker too? lol or even a strap wraped around an i beam/rafter? i've done some crazy shit to get some things done lol hey if it works right?
    Check the motorcycle section for more info.
    -Ant.
    -Ant.
    I made one, I took a crank bolt and cut the stud off so there is only a nut, and then welded it onto a old cheap socket...waaalllaaa
    No because its inverted re re
    IA's Transformer God obd1kenobi's Avatar
    29th Chamber
    here's four tools
    GeckoSquad / Skull Platoon
    sexxxy
    Does his tat say Cadillac? lolol FUcking loser.
    -Ant.
    cady for gangstas
    rollin 91 da egpower904's Avatar
    Dallas, GA
    jersey shore is a show full of heffers and fail.
    that frame should look sick, i would do it and the wheels white
    DA SQUAD MEMBER #70
    91 da/95 gsr/boosted/awaits tune....
