Results 1 to 18 of 18
Thread: Smoke coming into interior
    Default Smoke coming into interior
    I have a 97 civic ex has a swapped jdm gsr in it. When "i get on it" a shit load of smoke starts to come in the interior of the car. Not sure where its coming from. Is this just an exhaust leak? I know a I have one right now cause the previous owner had a Custom exhaust put on it. I am going to buy a new exhaust system and a test pipe.
    Новак 5speed's Avatar
    Conyers, GA
    If it is a shit load of smoke you might want to put the car on a riser and check everything out. You most likely have a bad amount of carbon dioxide in your vehicle even when you can't see or smell it. If you start getting headaches and other pains constantly then you gotta a really bad leak. Good luck!
    Amen.
    IA Member d00d's Avatar
    Jul 2009
    macon,ga
    Get that car on a lift asap, carbon monoxide is no joke.
    yeah i have my windows down most of the time my clothes smell like exhaust fumes... i get headaces every so often depending on how long i am in the car. fuck... will replacing the exhaust help fix this? i can't imagine anything else causing this problem except the exhaust
    vanilla sky.
    my guess would be no donut gasket/
    Stang Mod slostang's Avatar
    Southside
    toss two of these in the oil.
    FREE BUJU StarBwoy's Avatar
    IDK
    check your shifter boot hole
    center field
    is the car gutted
    Conyers, GA
    There should be no reason an exhaust leak should be leaking like that. You probably have a hole that you dont know about in the body and its seeping through. Get the fucker on a lift and check it out. I say stop driving it for now if you have another car. If you already get headaches, you should stop as soon as possible. Just replacing the exhaust wouldnt fix it. There is another problem somewhere on the body of the car. Is it burning oil? Any funny noises?
    Amen.
    yeah def dnt make yourself sick, i had a gas leak one time and it made me sick as fukkk throwing up for days, and bad headaches...
    will it fill with smoke at idle or just your foot on the gas in neutral? even if you did have an exhaust leak it shouldnt smoke that much unless you have bad rings and a leaky exhaust..etc etc etc
    Quote Originally Posted by jdmcivcc View Post
    Southside Ridin HATCH
    ^ YEA
    Is the damn car gutted? ghetto tucked? anything?
    IDK
    yea check the shifter boot first there a black rubber thing and some time it come off when shifting
    http://img126.imageshack.us/i/im0007089ku.jpg/ it should look something like this
    x2!
    the rubber stopper under the car, above the shift linkage might be missing!
    damn, i want that penis
    ^^^^^^^^^^^BBBBBBBBBBBBBBBBBBBBBUUUUUUUUUUUUUUUUUU TTTTTTTTTTT
    He still has an issue with the exhaust leaking out the Manifold or something.
    Hole or No hole..
    Check The Manifold Gaskets and collector gasket...
    Newnan
    fix that shiiiii bwah!
    learn to english
    Hole or No hole..
    true....i'd say to check your not missing any bolts holding your header n testpipe/cat together. 1 might be missing. also like was stated above check the condition of doughnut gasket. if your running a 2-piece header, check that gasket.
    Conyers, GA
    UMMMMMM....Donuts!
    Amen.
