Results 1 to 18 of 18
Thread: Wiring a b18a1 in a delsol help
    No go del slo Jdmsol's Avatar
    Nov 2009
    Bremen
    Default Wiring a b18a1 in a delsol help
    I got a b18a1 ls non vtec complete swap out of a da and I'm putting it in my sol. Can someone tell me what I need to do as far as which engine harness do I need or modify cause the one that came with the motor want work cause my sol was vtec. I do have the del sol vtec harness still
    JDM as......
    93 accord cb7
    (traded)
    93 del sol eg1 (traded)
    94 integra dc4 (sold)
    96 db7 ls-t (daily)
    center field
    your harness should plug in pretty much , is it a obd1 motor out of a da lmk
    Nov 2009
    Bremen
    I think so but does it matter that my harness is a vtec?
    JDM as......
    93 accord cb7
    (traded)
    96 db7 ls-t (daily)
    center field
    no it dont matter , u will have to xtra plugs left over for vtec, u need to run the ls ecu
    You will just have to extend some things, and not use some plugs. from your del sol harness of course.
    about this far.
    if you use the del sol, your going to have to make the o2 wires and the oil pressure sensor plug wires long and make the intake manifold sensor wires long too.
    Imy ruckus
    ~Lagg Squad~
    <turbo negros>
    I put the sexy in dyslexia.
    R.I.P steven bond....
    del sol vtec shift linkage is the biggie, and also ditch the cable trans and get a hydro one, it will actually be cheaper this way. Get all the right equipment, its really easy.
    My line of work
    www.internationaljets.com
    Nov 2009
    Bremen
    Yea I'm tryin to get a hydro tranny and I already have the shift linkage it a b series linkage for a del sol
    JDM as......
    93 accord cb7
    (traded)
    96 db7 ls-t (daily)
    1% ER. twiztid cc's Avatar
    over yonder...............................................................yeah here
    i think that is obd-0 i'm sure it is
    Quote Originally Posted by bdydrpdmazda View Post
    I love porn, the gay kind
    Quote Originally Posted by 03RCode View Post
    Quote Originally Posted by b@d @pple View Post
    i would slit her throat then fuck the hole
    center field
    Quote Originally Posted by twiztid cc View Post
    well u got obd0-and obd1 da,s , he says its a obd1
    Quote Originally Posted by dirk-diggler View Post
    i sold him the motor
    Hope you have a Hydro tranny...
    Quote Originally Posted by Tree View Post
    Nov 2009
    Bremen
    Hell I thought it was obd1 since it is out of a 93, the motor is a 92 an its still obd1 unless its been converted right?
    JDM as......
    93 accord cb7
    (traded)
    96 db7 ls-t (daily)
    Quote Originally Posted by Jdmsol View Post
    If it's not been converted it should be OBD0 what color are the plugs on the motors if any of them are white thats normally a good indication that it's OBD0 OBDI and OBDII have grey plugs
    Nov 2009
    Bremen
    Quote Originally Posted by envision View Post
    All the plugs I see are grey obd1 right? How else could I tell?
    JDM as......
    93 accord cb7
    (traded)
    96 db7 ls-t (daily)
    90-91 da integra's are obd0 and the 92-93 integra's are obd1. Lots of mis information in here. So basically it is identical to a b18b1, minus the breather box being different. But basically get all the right mounts, the right ecu, and minimal wiring then it should all be good.
    My line of work
    Nov 2009
    Bremen
    That's what I like to hear lol thanks bro!
    JDM as......
    93 accord cb7
    (traded)
    96 db7 ls-t (daily)
