Results 1 to 13 of 13
Thread: shifter vibrating in integra
    Oct 2009
    G-Net G.A.
    Default shifter vibrating in integra
    hey guys j.w. my shifter vibrate a lot to the pint it make noise when i drive it. when im going about 60 + the noise get louder... it does have a short shifter but i dont know if it bc of the s.shifter or not.
    what can i do to test to see if its the motor mounts / tranny / s.shifter.
    thanks guys.
    Aug 2009
    check your mount... maybe loose bolt
    Oct 2009
    G-Net G.A.
    thanks ill check tonight when i get home.
    Oct 2009
    G-Net G.A.
    Quote Originally Posted by Austin? View Post
    i checked but every thing is still good
    I don't care cwhiteboy's Avatar
    Northeast atlanta
    Are you missing the rubber boot, the one underneath your "normal" boot that seals the inside from the outside? Do you have aftermarket mounts or inserts? That may cause your mounts to be too stiff... Just some ideas, hope you find out.
    yeah check your bushings. i have a honda short shifter in my car and it does the same thing. it could be partly because its not a honda either. lol
    need a si shell tpike09's Avatar
    Aug 2009
    milledgeville ga
    Quote Originally Posted by DeeAOne View Post
    my civic does it and it because i dont have the bushings inbetween the shifter and the shiftlinkage because the stock bushings will not fit with a short throw
    VTEC addict:jerkit:
    Oct 2009
    G-Net G.A.
    Quote Originally Posted by cwhiteboy View Post
    i checked it its still there maybe i just need new inserts... but thanks for the help bro.
    No Advertising unless you pay you are Warned...
    IA MGMT
    Oct 2009
    G-Net G.A.
    yep i checked i think i need new bushing.... my friend was telling me about power bushing that i can get to see if that will work thanks by the way for the help
    IA MGMT
    On this topic, which shift bushings would you use? I think I need a new set to clean up some sloppiness in my shifter as well. And I have the vibrating shifter thing too...mine will actually whine near redline.
    20 side of thangs
    shifter vibrating? get your bitch to sit on it
    Sedan Power JDM4doooooor's Avatar
    Sep 2009
    ur linkage might b touching ur exhaust pipe!!
    my short shifter was shacking alot 2 n i found out it was touching my exhaust!!
    just trying to help!!
    West palm beach
    Quote Originally Posted by JDM4doooooor View Post
    THIS
    NO ADVERTISING
    -IA MANAGEMENT
