Results 1 to 23 of 23
Thread: Looking into getting an Integra.
    I'm probably wrong alex14's Avatar
    Oct 2009
    Stockbridge
    Default Looking into getting an Integra.
    I've been thinking about getting an Integra as a DD here lately and i was wondering what i need to look for when i buy one. is there anything i need to look out for? What are some of the problems that they have.
    looking to get a 94+ 5-speed.
    SwiperNoSwiping!!
    gotta watch out for 3rd gear grinds
    u remind me of a wigger !
    Oct 2009
    Stockbridge
    What causes that? how is it fixed?
    SwiperNoSwiping!!
    im not really sure what causes it, i think with time the synchros inside the tranny just wear out and the way you fix it is to get the transmission rebuilt and make sure they install new synchros.
    Jul 2009
    first sign of someone beating the shit outa the car.....
    if it grinds at high rpm....... the motors prolly been beat on....
    Jul 2009
    using syncro mesh will do it too after a while...
    Oct 2009
    Stockbridge
    Alright. As far as I know it hasn't been beat on. The current owner is a chick and I know the previous owner and he takes good care of his stuff.
    How do I check the motor mounts?
    SwiperNoSwiping!!
    Quote Originally Posted by alex14 View Post
    pretty much just look at them. If they look old/cracked, and or when you rev the engine a little and you can see it moving, it may be time for them to be replaced. Not neccesarily though, only if the rocking is excessive.
    Oct 2009
    Stockbridge
    Alright. So just making sure that there are no grinds in the trans is about it?
    SwiperNoSwiping!!
    I would also check the engine for any/all oil leaks or oil burning as well.
    Oct 2009
    Stockbridge
    Good deal. Thanks for your help guys. I'll post up more info as I get it.
    Jul 2009
    also drive in gear...... like 40ish in second. LOAD and Let of the pedal..... not so much to buck the car but enough to make things that are worn make noise..... like motor mounts,,,,, get car to 65 and press brake.... if they shake it might need rotors or worse tie rods......
    theres alot to checking a car......
    ANDREW AKA DEAF GUY 404 THE DC4's Avatar
    southside
    take a hard look at the title n check if its clean before hand $$ to the seller.
    NIKON Squad member 05
    Mah shit thread
    you can google the VIN and it will tell you how many incidents its been in. it wont give you the complete carfax but it helps a little to see how the car has been treated.
    also push the car and see if it smokes and check for oil leaks, how temperature moves, and make sure it passes emissions.
    damn, i want that penis
    Out in the Boonies
    1. Clean and clear title.
    2. Oil leaks, radiator leaks, etc.
    3. Mechanical problems
    4. Electrical problems
    5. Engine problems (valves tapping/etc.)
    6. Transmission problems (grinds hi/low rpms)
    7. Body damage
    8. RUST
    Just a few things to look into, but you get the point. Also it's not just for Integra's, but almost any car you would buy.
    Oct 2009
    Stockbridge
    I know the basics of thisngs i need to look out for when buying a car, I was just looking for things i needed to check that were integra specific.
    KINGZOFSOUTHTOWN
    Norcross
    There isn't anything specific to check, just go through the process like every other car to see if there is any problems.
    -hmgdrfter-
    PP TRACK 350Z
    423 KING
    Chattanooga, TN
    look at service records too and all the other stuff mentioned above, mine is for sale
    18x9 +24 18x10+22
    Jul 2009
    one thing to check for on the integras specifically is slow acceleration...... fortunaely i fixed that by taking the integra engine and drivetrain, building it, turboing it, and swapping it into a civic........
    btw mines for sale too
    Newnan
    you can check your mounts by pulling the e brake and putting it in 1st gear and easily moving the car in 1st gear very carefully without moving.. do the same in reverse.. this ensures that the transmission mount and motor mounts are not moving too much.
    learn to english
    Oct 2009
    Stockbridge
    Quote Originally Posted by Humphries View Post
    Thanks man. I'll do that.
    Don't really know of any Teg specific problems.
    As with any car, I would suggest a mechanic to look it over. That way you can know what things might need attention. Check for body repairs (orig vins, paint runs, over spray) too. I always like knowing if a car has been in a wreck and how bad. But if your sure you know what to look for by all means carry on.....
    Oct 2009
    Stockbridge
    Thanks for the help guys. I'll post something up when I get it.
