Results 1 to 16 of 16
Thread: head
    Default head
    so heres the deal, i bought this b16, about 2 months ago blew a head gasket, he removed the head, took it to the machine shop got it all done up blahblahblah
    well the dude reused the OEM headbolts which once they are tq'd you are supposed to replace them. about 2 weeks later it started smoking again, i have some Head Studs, would it be safe to just pull the head, put a new gasket down, and use the studs, or would it have been possible that the head could have warped again?
    1994 Honda Civic SI - KPOWA
    HybridRacing/ALLINFAB/KARCEPTS/K-Tuned/Bride/TopOneAERO
    West palm beach
    depends if it got hot enough, just have it checked or lay a straight edge on it and see.....
    NO ADVERTISING
    -IA MANAGEMENT
    www.jjspec.com Macon, Ga
    You said it started smoking again. What color is the smoke?
    roberta
    exactly^....white,grey,black??
    YR88 Win! Romeo's Avatar
    Middle Ga.
    Quote Originally Posted by jcs View Post
    exactly^....white,blue,black??
    Grey... LOL.
    roberta
    Quote Originally Posted by Romeo View Post
    Grey... LOL.
    lulz
    did it run hot?
    Quote Originally Posted by jjmastertech View Post
    Quote Originally Posted by TommyD1919 View Post
    did it run hot?
    x2
    Oct 2008
    general rule of thumb:
    white smoke = head gasket issue
    black smoke = piston ring/ valve issue
    grey smoke = head gasket and piston ring
    blue? = some radioactive shit is going on get the **** out of there
    i am assuming that if the head was brought to a machine shop, then they would have inspected the valve and check for warping issues...so those are pretty much eliminated unless you went to like tim bob shop or something....also sometimes the smoke could just be coming from the muffler itself with shit inside it.....take the muff off and run a can of carb through it to see if it still smokes
    Middle Ga.
    Quote Originally Posted by k3tsurui View Post
    You must be new to this or something. LOL. Blue would be an oil issue also, genius.
    Oct 2008
    I was being sarcastic, but thanks for the insight
    West palm beach
    Grey... LOL.
    x2
    Quote Originally Posted by 96hatchCX View Post
    LOL, none of you answered his question. He just wants to know if he needs to have the head re surfaced again before it goes back on. No one here can know that without seeing it.
    NO ADVERTISING
    -IA MANAGEMENT
    lol u must need that big font to see.
    West palm beach
    more then you know....
    NO ADVERTISING
    -IA MANAGEMENT
    It's all about JDM.
    CA to GA
    Resurface the head, buy a new OEM honda headgskt, and new OEM head bolts. ANd you should be ok. just did mine recently, becuase my exhaust smoking white, and engine overheating. And car runs fine now.
    You gotta understand, reusing old head bolt is taking a risk (bcuz they go under alot of heat, and material overtime becomes weakened.) But if you do decide to use ur old bolts, make sure you mark them (puting them back in its original order and slot), and torque them correctly.
    white smoke =Coolant
    White smoke with a bluish tint= Oil
    Grey smoke=Exhaust fumes
    Black smoke=Fuel
    I would NEVER reuse a OEM headBOLT, Headstuds are $100 and reusable, id go with some ARPs just to be safe
