Thread: Heater doesnt work
    Default Heater doesnt work
    Just wondering why my heater doesnt work in my 96 civic dx. Too cold to be dealin with this. lol
    When i turn the heater on i dont feel any air at all even when i blast it to full
    heelllppp
    Quote Originally Posted by k20ej8 View Post
    heelllppp
    make sure the core is getting coolant. make sure u have coolant. make sure u have no leaks. make sure your fan is blowing.
    Dec 2008
    Northside
    is the hose hooked up?
    11.3 @ 117
    Midnight
    Auto
    M
    ORRIS TUNING
    Southside Ridin HATCH
    You dont feel ANY air?
    check the blower motor, test it.
    :noitacoL
    ^what he said.
    Jul 2009
    mayeb your heater bearing went out
    barrow county
    x3 way to check if its still good is to take it out and hook a negative and positive wire from your battery to the blower motor ( hold the bottom of the blower motor and grip it good ) it should spin. if it doesnt than the motor is dead. if it does than your switch is bad or no power is going to it
    Quote Originally Posted by blue_gt View Post
    NOOOOO
    Want to start a fire!!!
    hOLLA SHITT
    take a test light and check the power and ground from the blower connector you can turn the switch on and off to see if its getting P&G
    If it is tap on the blower while your switch is on High if it comes on replace it, if it doesnt replace it because your getting a P&G so it has to come on... If your switch is on high and it works but not on the low speed its your blower resistor. If you don't have a P&G check fuses
    Quote Originally Posted by dallasb84 View Post
    Idiot
    barrow county
    Quote Originally Posted by ASE*Tech View Post
    NOOOOO
    hOLLA SHITT
    how the hell will it cost a fire to test the blower motor lmao
    its a 12v current that goes to the blower motor at high speed
    www.jjspec.com Macon, Ga
    Turn it on and hit the bottom of the blower motor with your hand. If it starts working it will be time for a new one as the brushes are about worn out in your blower motor.
    Love Life
    Alpharetta
    Can't overlook faulty blend doors. Make sure they shift properly when you slide the climate control from side to side.
