Results 1 to 29 of 29
Thread: automatic tranny problem
    The Slums of GA
    Default automatic tranny problem
    so my buddy change his radiator on his 97 integra (automatic). He forgot to reconnect the Transmission line that goes to the lower part of the radiator.
    He started the car and there goes all the transmission fluid all over the driveway..he drove the car in and out of the garage a few time and now it won't go in to gear. we got some tranny fluid for it but it still the same.
    On the shifter (P-R-N-D4-D3-D2-D1) there is no light on the D4.
    the car will shift to all gear but feel like it on N and on gear P is grind(alot).
    Hope some one can help me out on this!!!
    tranny is fucked sry
    The Slums of GA
    damn, just like that?
    yah the clutch packs in the auto tranny burn fast if not kept properly lubed
    The Slums of GA
    can it be change out?
    cheaper to just replace the tranny
    let it cool down, check the fluid when the engine is off not running and try again after hours of cool down... If that was what really happen i think you will be ok
    Certified Gearhead schia89's Avatar
    Oct 2008
    transmission gone frank, honda transmissions are really weak
    Quote Originally Posted by Tech5 View Post
    good to see u out an about the internet again. how u been feeling.
    The Slums of GA
    he start it this morning when it was cold.. same result.
    The Slums of GA
    just to let you know, i never work on an automatic before.
    let that be said:
    is it the same as a 5 speed clutch? is it located on the block or in the tranny?
    Norcross
    just change out the tranny. its easy. jus make sure u spin the torque converter in the tranny before u put it in
    Quote Originally Posted by wanggsticky View Post
    inside the tranny there are a series of small clutch packs that look like this:
    The Slums of GA
    thanks,,
    auto tranny look so damn differant from a 5speed...
    thanks alot
    LAWRENCEVILLE
    i got a trans for this!
    Hella stock member!
    The Slums of GA
    can he used an obd1 and obd2 are interchangeable right???
    all plug and play?
    no they are different. the area where the shifter connects to the tranny. they are to different styles.
    The Slums of GA
    let just say that we buy an obd1 tranny. (cheaper)
    we have to have the obd1 shifter cable?
    or can the one we got will work?
    thats the part im not sure of.
    honestly, didn't think automatic transmission would mess up 8D unless yall was manually shifting it from d1,d2,d3,d4 cause i use to do that on my camry! and datt bishhh chirpps lol hope u get it fixed though, and i see automatic trannys run for cheap cheap
    /Oo ___A___ oO\
    |=_/_______\_=|
    Quote Originally Posted by VickNotic View Post
    its doesnt have to be shifted. that like saying u can run your engine with no oil just dont rev it.
    Nov 2009
    Huntsville, AL
    CONVERT!!!!
    Aug 2009
    you drive d1,d2,d3,d4???
    that is good for you!
    aint my thing
    IA MEMBER turbob20's Avatar
    LaFayette Ga.
    when the line was left off leaving a break in the flow the pump went dry and starved the clutch packs and converter. find some way to push the fluid through to bleed air out just like if an oil pump on some things are installed dry it wont pick the oil up. it needs to be reprimed if not ran too long and fried.
    Unknown
    Oct 2009
    Default Honda Trannys?
    weak... i on think so...
    Make sure you put enough fluid back in it. Usually just dumping the fluid out won't hurt anything immediately. The clutches work off hydraulic pressure, and if there is no fluid, there is no pressure, which means there is no clutch apply. If this just happened in the driveway, I seriously doubt it hurt it, unless the car just ran for an obscene amount of time with no fluid. If that was the case, it would have damaged the pump from no lube. Dump 3 or 4 quarts of fluid in it, and see if it doesn't start working.
    The Slums of GA
    god damn!!!!!
    so he bought another transmisson last week right?
    last light we was getting ready to lift the car up to remove the axle.
    i notice that the PHUCKING AXLE had poped out from the transmission.
    so i tapped it back in and that is it....
    we have never even look there before. F&$@ing waste of time and money!
    now he got another tranny that he don't even need. (obd1 tranny)
    the car run fine now!!
    thanks to everybody that try to help
    LoL
    barrow county
    LMFAO
    well just remind him not to run the car without fluid. dont matter if its oil/tranny fluid/anti-freeze/vtec fluid w\e.
    they all end up with a bad result.
