Results 1 to 11 of 11
Thread: injectors
    Jul 2009
    Default injectors
    ok so im lookin at all these types of injectors and wondering wtf this shits all about
    can some one give me the run down on this
    im seein
    peak and hold
    saturated
    low hi impedance
    resistor boxes
    injector driver
    WHAT THE FUCK
    i gots a obd2 b18b will be converted to obd1 with a jumper harness and dizzy and chipped computer
    also will be going turbo with a stock sleeve bottom end
    please help
    Don Mon SiRed94's Avatar
    Morrow 30260
    Quote Originally Posted by dallasb84 View Post
    im seein
    peak and hold
    saturated
    low hi impedance
    resistor boxes
    injector driver
    WHAT THE FUCK
    please help
    Peak and Hold are low impedance injectors, meaning they operate off of ~1-4 ohms and require a resistor box. Saturated injectors are high impedance, meaning that they operate off of ~10-16 ohms and do not require a resistor box. If you are going to turbo your engine, you will most likely be using low impedance injectors, because most high CC injectors are peak and hold. If you are not expecting more than 350 whp, you will probably be fine with DSM 450 cc's. But if you will be around 300-350, you will be running a very high duty cycle. You can find a resistor box on almost all older model fuel injected Hondas, and can use it with the DSM's. It is simple to wire, you can find instructions online.
    Jul 2009
    i dont really mind what i get......
    im looking at the precision 580's (low impedence 2 ohm) and 630's details are.....
    These are Siemens Deka 630cc high impedance (saturated) injectors (no need for a resistor box). Run like new (used only about 10,000 miles, no racing). Ran them for 2 years (80% load MAX) on a turbo Honda S2000.
    O-rings should be replaced to avoid leaks (available at any Honda dealer or autoparts store).
    Will fit many other Honda/Acura vehicles. Price is for all 4 matching injectors (Siemens 107961)
    Wide Angle spray pattern (ideal for multivalve heads)
    Static Flow Rate: 60.56 lb/hr = 668 cc/min = 458 g/min (+/-6%)
    Dynamic Flow Rate 2.5ms PW @ 100Hz @ 600KPa: 19.5 mg/pulse (+/-6%)
    Coil Resistance: 12 Ohms (This high-impedance injector will work with all factory ECM/PCM injector drivers)
    Gain: 0.11ms/mg
    Offset: 0.055ms
    Turn on time @ 14VDC: 1.14ms
    Turn off time: 0.85ms @ 600KPa
    Spray Pattern: Cone (4-Hole)
    Connector: Minitimer (Bosch EV1)
    what should i get and how much hp will these support
    Flowery Branch, GA
    It really depends on the tune, but should be over 350 to the wheels on those injectors on a front wheel drive. On the Subarus and Evos we use 565's to around 300 whp but Subarus have a much higher drive train loss and like to be run rich.
    ---Mike
    the 580's are good on a honda to 350ish @ a good duty cycle. the 630's 400-450ish. if they are the same price i would go w/ the 630's if they are saturated and are plug and play...less to deal with wiring wise and lower duty cycles @ the same power levels.
    Flowery Branch, GA
    +1 lower injector duty cycles is always a good thing! On my personal car I ran 820's when only 650s were needed just for that extra head room if I decided to expand....course now with my new build I am going to have to upgrade to 1000cc injectors and up the fuel pressure to push them up to 1400cc injectors in order to run E85 with a BIG turbo. Course I am also shooting for high 400's at the wheels.
    I know as a tuner, unless you go ridiculously big, the size of the injector being a bit larger than needed is no problem at all and gives you the ability to expand later without having to go out and buy new injectors.
    The injectors you buy will also make a big difference. The new Bosch 1000's are 100x better than some of the previous options on the subarus and Evos and will idle better than stock!
    ---Mike
    E46 M3 Z0_o6's Avatar
    Suffolk, VA
    that's why i went with the ultimate racing top feed 1000cc injectors on my subaru- headroom. i think right now they are only running at a max duty cycle of like 65% lol!
    Who knows?
    Flowery Branch, GA
    What turbo?
    ---Mike
    slower than you Incontt's Avatar
    Mableton, Ga
    call one of the sponsors hear and listen to what they tell you...batlground...mainstream etc.....no need to reinvent the wheel.
    slower than you
    Jul 2009
    found some cool info so im bringin this back from the dead...
    maybe itll help someone
    click the like for honda specific injectors and driver types..... helps with swaps and ecu matching and injector types...
    http://www.jspecautosports.com/files...chcenter3p.htm
    Northwest Georgia
    If you want a high capacity injector over 750cc, i recommend Injector Dynamics.
    They have a 1000cc SATURATED injector and a 2000cc SATURATED(YES SATURATED) that is capable of up to 3700cc of fuel supply at 130psi fuel pressure, WHILE IDLING LIKE STOCK STOCK ON A BONE STOCK ENGINE.
    They are on my switch to list for the future.
