Results 1 to 22 of 22
Thread: LSVTEC Question probably best suited for Bearfoot
    Boosted 2 Perfection GSRTURBOTEG's Avatar
    The Jungle
    Default LSVTEC Question probably best suited for Bearfoot
    Okay IA I have completed my lsvtec swap and have everything hooked up, and ready to go...the motor turns over great no problems what so ever, but I am not getting any fuel to the engine. The fuel pump is not even engaging, does anyone know if I have to repin anything for the fuel pump using the 98 harness on a p28 chipped with chrome pro and jumper harness? I really don't want to put the fuel pump on a toggle swith if possible so if you know of something to trouble shoot through please let me know. I have the ecm here and cannot find anything so let me know what your experiences have taught you.
    Thanks IA
    Coulby
    Southside
    First thing that comes to my mind is Ground and Fuse
    The Jungle
    both good to go, I have already been that route.
    Thanks for the input!
    Southside
    What wiring harness and what chassis?
    The Jungle
    Running a 98 lx d16y7 non vtec wiring harness in a 98vic 4dr
    Quote Originally Posted by EJ1soSlo View Post
    and main relay get a test light. see if u have power going in and coming out.
    The Jungle
    And if I dont have power coming in and going out? Also the other senario, if I do have power coming in and going out?
    Quote Originally Posted by GSRTURBOTEG View Post
    find out which 1 u are working with ill give u the rest of the info.
    Southside
    Did you change from factory to after-market fuel pump ?
    The Jungle
    No still stock fuel pump
    Norcross
    maybe check ur fuses. the ecu fuse may be blown
    The Jungle
    Quote Originally Posted by j0nbunklah0m View Post
    That is what I am thinking but I cannot find any blown fuses.
    Thanks for the imput
    YR88 Win! Romeo's Avatar
    Middle Ga.
    Main relay?
    Southern Speed
    Macon
    coulby have you messed with the chip at all? As in taking it out and putting it back in.
    The Jungle
    Quote Originally Posted by DarKStaR View Post
    Negative I have not even opened the ecu since it was tuned
    Southern Speed
    Macon
    Only other things i can think of is the main relay or i know in j. roberts hatch his ground thats under the driver seat under the carpet had gotten loose and would cut in and out and would not crank sometimes.
    Southside
    I'm even starting to question if the fuel pump is good anymore
    im still waiting on relay test results.
    Southside
    x2
    only stabs in the dark now
    The Jungle
    Hey we got it, the relay was unplugged.
    Thanks for everybodys input and assistance.
    just to think that could have been found out on the 21st. happy u got it running.
    The Jungle
    yeah, but you know its not fun without drama.
    Thanks again for everyones help and input!
