Results 1 to 35 of 35
Thread: ??? Whats the deal with H Series
    Stay Humble
    WV
    Default ??? Whats the deal with H Series
    Why do i rarely see H series motors being tuned etc.
    its always b series. and even d series more than the H.
    something i need to know?
    Southside Ridin HATCH
    U aint lookin hard enuff
    Stay Humble
    WV
    well i mean i see way more than b.
    i see h just not as much.
    they are both really god right?
    I see it as a more of drag engine then a track car engine. B Series is light and easy to maintain vs the H motor is more pain.
    Stay Humble
    WV
    ha what do you mean more pain?
    in the past month i've tuned at least 6 if not more. plenty of people do them, but b-series tend to be more popular b/c they are already in many of the cars stock and some people don't feel like dealing with the extra effort that swapping in a h seems to be.
    because b and d are in way more cars than h every will was.
    Certified Gearhead schia89's Avatar
    Oct 2008
    Money n h series requires more modifications
    RE30
    B-Series
    Cheap swap for good power
    Easy "plug and play" swap
    Parts are cheaper
    H-Series
    A little bit more expensive
    Requires some modifications
    Heavier motor put more weight up front(+150-200lbs.)
    More fuel? lol
    We're currently doing a H-Series Integra and it does need a little more love then a B.
    Jay G. 1439/2000's Avatar
    Location, Location...
    Quote Originally Posted by xlilvi3tx View Post
    B-Series
    Parts are cheaper
    H-Series
    More fuel? lol
    So you are saying that an H22 weighs 200lbs more that a B16? LOL
    co-lame-bus
    another thing to take into consideration; Fiber reinforced cylinder walls tend to wear quicker resulting in higher maintenence costs (rings, etc) or more modification costs ( replacing oem sleeves with aftermarket units).
    Where Am I
    B-Series
    Parts are cheaper
    H-Series
    A bit cheaper!
    More fuel? lol
    Edited look it up a bit cheaper then the B's expectially if u compare to the B18c5, which is closer in range for power, not B16's which aren't even close........... But fuel mileage sucks!!!!
    rolla rollin
    middle GA
    yeah a h series is like a v8 it drinks the gas alot quicker!
    RE30
    Quote Originally Posted by Turbodude06 View Post
    yeh you're right lol the motor itself is cheaper. i just checked on tigerjap. lol i remembered h-series were more expensive but nvm
    Drink more gas? I understand a bigger engine needs more fuel, however it may be that the H required premium fuel whereas the D and B require regular. Even though people say you can use regular 87 unleaded in the H, I always used Premium. Just can't beat that torque straight from stock. B16C5's are still going for $2400 to $4000 today. You can get a H22 for under a grand at JHOT I know.
    I Am, A Stunt Man
    my friend went to jail and sold me his h22a for 325 bucks and i did a full oem rebuild and it was a total of around a grand, if you look around you can find what you need, but whats gonna get you is getting it put in the car, like wire harness obdo to obd1 harness, mounts radiator,shifter box and traction bar and alternator relocator and hydro to cable, that round up to a lot, ive spend around 3 grand on the motor plus getting it put in the car.
    co-lame-bus
    16b c1 c5 also req premium.....
    Where Am I
    Quote Originally Posted by hatch22 View Post
    Yea I was just about to say that too... Hell the only B that doesn't, is the LS B18b & a.....
    co-lame-bus
    Usdm B16a can run off reg due to lower comp ratio 9:1 I believe not sure abt jdm b16a tho
    shit i tried that once thinking that dead wrong.
    Texas
    ANy thing can run regular b to d.... Just results vary. I ran regular (87) on my boosted d series. and it was making 2XX. But that in yo pipe and smoke it.
    Stay Humble
    WV
    damn, im learning some good shit haha
    Certified Gearhead 01CDMLUDER's Avatar
    The jdm type s H22 has 225hp stock
    Stay Humble
    WV
    what kind of TQ?
    Hand Built Self Made batlbrandon's Avatar
    around
    Quote Originally Posted by SoLJames95 View Post
    Yes "anything" can run regular (cept diesel motors ), but that doesn't mean you should. I think the biggest issue with the h series swap is the shifter assembly. Going from hydraulic to cable isn't very hard but it is more work than a b series. Overall it is not a hard swap but requires a little more work, it really just comes down to what you plan on doing or wanting out of the car.
    Where Am I
    Quote Originally Posted by chaseamundo View Post
    what kind of TQ?
    Around 160tq... I think 164?
    But yea I ran reg. in my first GSR for like three months, it never did anything but I had no idea, it was my first honda and I didn't know it had that much compression.... If it don't knock or ping, and ur not beating on it. Not that big of a deal though ..................
    Stay Humble
    WV
    what would you say is the best motor to go NA with?
    SOUTHERN SPEED
    macon ga
    Im one of the six h22 motors scottie has tunned in the last month and it put down 231-171 and i just checked my gas mileage 34.5 miles to the gallon. Ill be glad to give you the numbers the hatch started with and finished and how many miles i went for proff if anybody wants it. In my opion h22 is defenently the way to go for all motor its just cheap horse power to me but like it has already been stated it takes a little more to do the swap its not as easy as a bolt in plug up process like b series. as for frm sleeves wearing out come on ive got ten blocks at the shop with over 200,00 miles that are perfect and they actualy run cooler and less friction the only down fall is you cant run forged pistons in them. If your going all motor you can buy some type s pistons shave the head a little and get all the compression you want with out even having to buy high compression pistons. With a h23 crank and type s pistons the piston sticks out the block twenty thousand already so no need for high compression pistons unless your building a all out drag motor. All the obd1 blocks are closed deck blocks actualy great for boost but stock h22 pistons have weak ring glands so you have to run another piston for boost which means you have to sleeve the block and thats why alot off people prefer b series over h series because they come with steal sleeves but they have a moly piston now thats great for boost that works in the frm stock sleeves of a h22 . There are plenty of people making weal over 500 horse power with a stock h22 block with just pistons and rods. I went through all this b series h series with all my friends 8 years ago and one put a supper chargered gsr in a hatch the other put a turboed b16 in a hatch and i put a stock h22 in a hatch they all 3 run mid 13s and i had half the money in mine with no power adder hope this helps.
    252plus hp and 34.5 miles to the gallon all motor. 12.2 at 111
    Stay Humble
    WV
    damn, 500 out of h22 with pistons and rods?
    ..fresh and clean... h22civic09's Avatar
    Aug 2009
    monroe, ga
    ive got a jdm h22a in my civic and i love it. regardless of the cost, its worth it. it should have been a stock motor in the civics. as far as gas mileage ive got a 10 gal tank and get about 200 to 230 mi. a tank,with some performance upgrades
    Stay Humble
    WV
    so H series are more powerful to sum it up?
    ..unknown
    I go with H-series. But at the same time all depends what car you are putting it into. To put a H in an accord its simple..
    I Am, A Stunt Man
    h22 jones, i want your setup haha, what was your price list when getting all that, cause all i have on my h22 ef is skunk 2 cam gears haha, lets build my h haha
    SOUTHERN SPEED
    macon ga
    500 horse power on a stock bottom end with pistons and rods and a nice size turbo not all motor just wanted to make sure you wasnt confused. Ill give you my parts list i just sold my accord well gave it to my sister so i guess im going to build me a hatch now so i can play with my dad at the track but it is a very inexspensive build . The most cost is in the cams ,springs,and retainers. I had a f20b head laying around which comes with types springs so i just used them they been working fine for years with the skunk2 stage 2 cams . You figure cams gonna be around 500 and you can get types pistons shipped to the door for 200 thats the main cost .
    I Am, A Stunt Man
    hell yea!, im gonna get the cams, what crank did you use? cause im building mine for all motor, and i want it done right
Tags for this Thread
